Up to 20% off select tools
Nintendo DSi Outer Casing Replacement
Views: 22K
View statistics:
Past 24 Hours:
14
Past 7 Days:
79
Past 30 Days:
561
All Time:
21,705
Comments: 13
12 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
Parts
Tools
Introduction
Go to step 1 ↓
This guide has been updated by iFixit staff! Read the new, official guides here and here.
A guide on how to remove the entire Nintendo DSi case.
    1. Careful: steps 1-2 are sourced from a guide that's marked as in-progress.
      Nintendo DSi Outer Casing Replacement, Battery: step 1, image 1 of 1
      • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
      Ask FixBot
    2. Nintendo DSi Outer Casing Replacement: step 2, image 1 of 1
      • L Button.
      • Top of the battery pack.
      • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
      Ask FixBot
    1. Nintendo DSi Outer Casing Replacement, Lower Case Assembly: step 3, image 1 of 2 Nintendo DSi Outer Casing Replacement, Lower Case Assembly: step 3, image 2 of 2
      • Two screws are hidden underneath two rubber feet highlighted in red.
      • Use the tip of a spudger to pry the rubber feet out of the lower case.
      • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
      Ask FixBot
    2. Nintendo DSi Outer Casing Replacement: step 4, image 1 of 1
      • Remove the following screws securing the lower case to the body of the DSi:
      • Six 5.2 mm Phillips #00 screws.
      • One 2.7 mm Phillips #00 screw.
      Ask FixBot
    3. Nintendo DSi Outer Casing Replacement: step 5, image 1 of 3 Nintendo DSi Outer Casing Replacement: step 5, image 2 of 3 Nintendo DSi Outer Casing Replacement: step 5, image 3 of 3
      • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
      • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
      • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
      Ask FixBot
    4. Nintendo DSi Outer Casing Replacement: step 6, image 1 of 2 Nintendo DSi Outer Casing Replacement: step 6, image 2 of 2
      • Carefully lift the lower casing from its bottom edge.
      • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
      • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
      • Once the cable is completely removed, then you may take off the entire outer casing.
      Ask FixBot
    1. Nintendo DSi Outer Casing Replacement, Battery Board: step 7, image 1 of 1
      • Flip up the black latch and disconnect the D-Pad/Power Button ribbon cable.
      Ask FixBot
    2. Nintendo DSi Outer Casing Replacement: step 8, image 1 of 3 Nintendo DSi Outer Casing Replacement: step 8, image 2 of 3 Nintendo DSi Outer Casing Replacement: step 8, image 3 of 3
      • The power connector (with red and black wires) is difficult to remove without damaging it, unless you take a moment and understand how it works. Look at all of the photos for this step before continuing.
      • The connector is two pieces -- a white "male" piece (connected to the wires), and a beige "female" part (soldered to the main board).
      • There is a small "notch" in the female part, to give you a place to insert a small flat-head screwdriver. Put the corner of your screwdriver in there, and twist it gently to push the white part up (away from the main board). Do not try to pull it to the right (towards the battery board).
      • If it does not lift easily, try again with a smaller screwdriver. You might be pulling the female connector off the board, which will be difficult to repair.
      Ask FixBot
    1. Careful: steps 9-10 are sourced from a guide that's marked as in-progress.
      Nintendo DSi Outer Casing Replacement, Motherboard: step 9, image 1 of 2 Nintendo DSi Outer Casing Replacement, Motherboard: step 9, image 2 of 2
      • Remove 4 Phillips screws from the board.
      • Lift the main board from the bottom end and flip it over to reveal the last connector.
      • Keep the main board fairly close to the case, making sure not to damage the last ribbon cable holding it in place.
      Ask FixBot
    2. Nintendo DSi Outer Casing Replacement: step 10, image 1 of 1
      • Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
      • The motherboard should now be free from the rest of the device.
      Ask FixBot
    1. Nintendo DSi Outer Casing Replacement, Bottom Case: step 11, image 1 of 1
      • Remove the rubber front-panel button membranes from the device. Pay careful attention to where the buttons go, so you can replace them correctly.
      • A/B/X/Y button assembly
      • Select/Start button assembly
      • D-pad
      • Power button
      Ask FixBot
    2. Nintendo DSi Outer Casing Replacement: step 12, image 1 of 2 Nintendo DSi Outer Casing Replacement: step 12, image 2 of 2
      • Remove the plastic buttons and keep them in a safe place.
      • All of the buttons have "key" notches to prevent them from being inserted incorrectly (backwards or in the wrong place), but it can take a while to figure out where everything goes if they get shuffled around.
      Ask FixBot
    3. Nintendo DSi Outer Casing Replacement: step 13, image 1 of 2 Nintendo DSi Outer Casing Replacement: step 13, image 2 of 2
      • Flip the case open, and push the lower screen assembly out of the frame.
      Ask FixBot
    1. Nintendo DSi Outer Casing Replacement, Top LCD Screen: step 14, image 1 of 1
      • To make the repair easier, we recommend removing the bottom LCD screen prior to replacing the top LCD screen.
      • Using a spudger, or similar tool, pry out the 4 square screw covers.
      Ask FixBot
    2. Nintendo DSi Outer Casing Replacement: step 15, image 1 of 1
      • Remove 4 Phillips screws with a #00 Phillips screwdriver.
      Ask FixBot
    3. Nintendo DSi Outer Casing Replacement: step 16, image 1 of 1
      • Place a plastic opening tool between the front panel and top edge of the outer case. Slide the tool along the edge as needed to prop open the case.
      • With the screen facing you, slide the screen side down with your thumbs to separate the screen from the cover.
      Ask FixBot
    4. Nintendo DSi Outer Casing Replacement: step 17, image 1 of 1
      • Remove the antenna from the bottom left of the device.
      • Remove the microphone from the top of the frame.
      Ask FixBot
    5. Nintendo DSi Outer Casing Replacement: step 18, image 1 of 1
      • Use a spudger to pry the camera out of its place.
      Ask FixBot
    6. Nintendo DSi Outer Casing Replacement: step 19, image 1 of 1
      • Cables for the components in the upper half of the device run through the hinge, which must be carefully disassembled before continuing.
      • Start by pushing the sliding shaft in the hinge on the opposite side of the wires/ribbons.
      Ask FixBot
    7. Nintendo DSi Outer Casing Replacement: step 20, image 1 of 1
      • On the reverse side of the casing, insert the spudger onto the surface of the sliding shaft just left of the LED light channels.
      • Push the sliding shaft completely through the hinge until it stops and the hinge is released.
      Ask FixBot
    8. Nintendo DSi Outer Casing Replacement: step 21, image 1 of 1
      • The right side of bottom case should separate from the top case when you remove the sliding shaft.
      • Do not pull up too far or the wire hinge may be damaged.
      • Slide the top case to the right to separate the joint.
      • Weave the wires and ribbons through the wire hinge to completely separate the top and bottom casings.
      Ask FixBot
    9. Nintendo DSi Outer Casing Replacement: step 22, image 1 of 2 Nintendo DSi Outer Casing Replacement: step 22, image 2 of 2
      • The speakers are soldered to the ribbon cable attached to the upper LCD, so they must be removed at the same time as the LCD.
      • Lift the top LCD out of the plastic frame. Carefully thread the ribbon cable out of the hinge to avoid damaging it.
      Ask FixBot
    10. Nintendo DSi Outer Casing Replacement: step 23, image 1 of 1
      • To remove the speakers, use a spudger or a similar tool to gently pry them off.
      Ask FixBot
    1. Nintendo DSi Outer Casing Replacement, Outer Casing: step 24, image 1 of 1
      • On the bottom cover, use a screwdriver to remove the 3 Phillips screws holding the battery compartment.
      • Removing the 2 lower screws also removes the "L" trigger.
      • The "L" trigger has a spring behind its center and a small metal axle in its joint.
      Ask FixBot
    2. Nintendo DSi Outer Casing Replacement: step 25, image 1 of 1
      • Use a small tool to pry the battery compartment off the bottom cover.
      Ask FixBot
    3. Nintendo DSi Outer Casing Replacement: step 26, image 1 of 1
      • Use a screwdriver to remove the 5 screws on the stylus holder.
      • Also disconnect and remove the "R" trigger button, which is held in place by two of the five stylus holder screws.
      • The "R" trigger has a spring behind its center and a small metal axle in its joint.
      Ask FixBot
    4. Nintendo DSi Outer Casing Replacement: step 27, image 1 of 1
      • Under the stylus holder is the SD card port.
      • Gently lift the SD card port off the bottom cover.
      • Remove the metal shield and flap from under the SD card port.
      Ask FixBot
    5. Nintendo DSi Outer Casing Replacement: step 28, image 1 of 1
      • This picture shows the LCD screen, battery compartment, and SD card slot (metal shield and flap) with bottom outer casing.
      Ask FixBot
    6. Nintendo DSi Outer Casing Replacement: step 29, image 1 of 1
      • The complete DSi outer casing can now be replaced. Parts listed left to right: top cover, top LCD screen casing, touch LCD screen casing, and bottom cover.
      • Follow the guides for the replacement of the DSi components backwards with your new outer casing.
      Ask FixBot
2 other people completed this guide.
Author
with
rjcamero
56 Reputation
3 Guides authored
Cal Poly, Team 6-1, Maness Fall 2009 Member of Cal Poly, Team 6-1, Maness Fall 2009
CPSU-MANESS-F09S6G1
5 Members
48 Guides authored
1 Guide Comment
Pictures are too dark to properly see where the structures mentioned in the text are, but worse than this, Steps 21 and 22 do not properly explain the “twist” method that you need to use with extreme caution! This is the Achille’s heel of dismantling the device and if you’re gonna make a mistake, let this not be the one…
Murat Kiymaz - Reply Share
Past 24 Hours: 14
Past 7 Days: 79
Past 30 Days: 561
All Time: 21,705
