Up to 20% off select tools
Nintendo DSi Battery Replacement
Views: 41K
View statistics:
Past 24 Hours:
13
Past 7 Days:
91
Past 30 Days:
498
All Time:
40,613
Comments: 1
1 comment on steps.
Completed: 26
26 people have marked this guide "completed." Will you be next?
Favorites: 12
12 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Replacing your DSi's battery only requires a Phillips #00 screwdriver and a thin prying tool.
    1. Nintendo DSi Battery Replacement, Battery Cover Removal: step 1, image 1 of 2 Nintendo DSi Battery Replacement, Battery Cover Removal: step 1, image 2 of 2
      • Unscrew the two Phillips screws securing the battery cover to the lower case.
      • The screws remain captive to the battery cover.
      • Grasp the battery cover and lift it out of the lower case.
      • If it's difficult to grasp, lightly tap the opposite side of the device.
      Ask FixBot
    2. Nintendo DSi Battery Replacement, Taking out the Battery: step 2, image 1 of 2 Nintendo DSi Battery Replacement, Taking out the Battery: step 2, image 2 of 2
      • Using a spudger tool (or your fingernail), lift up the battery from the top.
      • There's a small tab on the top of the battery to make removal easier.
      • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
      • Grasp the battery and remove it from the DSi.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take care to align the positive (+) and negative (-) connections on the battery with the console.
26 other people completed this guide.
Author
with
Walter Galan
712,028 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 91
Past 30 Days: 498
All Time: 40,613
