Nintendo DS Main Circuit Board Replacement
Views: 35K
View statistics:
Past 24 Hours:
10
Past 7 Days:
87
Past 30 Days:
348
All Time:
35,111
Comments: 14
12 comments on steps, 2 guide comments.
Go to guide comments
Completed: 24
24 people have marked this guide "completed." Will you be next?
Favorites: 17
17 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is a guide that teaches how to replace a Nintendo DS motherboard also known as a circuit board.
The Nintendo DS is a video game console released by Nintendo proposing two screens working in tandem with wireless connectivity, and an integrated microphone.
The main circuit board holds and makes all communication between components of the device possible. Therefore, whenever the communication between the functioning components takes longer than expected or there is no communication, replacing the motherboard is a necessity.
The removal of the main motherboard of the DS is essential to access the screens and to replace other imperatives.
The replacement could be done in 10 simple steps.
Parts
Tools
    1. Nintendo DS Main Circuit Board Replacement, Battery: step 1, image 1 of 3 Nintendo DS Main Circuit Board Replacement, Battery: step 1, image 2 of 3 Nintendo DS Main Circuit Board Replacement, Battery: step 1, image 3 of 3
      • Remove the cartridge from the console.
      • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
      • Remove the battery door.
      • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
      Ask FixBot
    2. Nintendo DS Main Circuit Board Replacement: step 2, image 1 of 1
      • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
      Ask FixBot
    3. Nintendo DS Main Circuit Board Replacement: step 3, image 1 of 1
      • Remove the battery from the Nintendo DS.
      Ask FixBot
    1. Nintendo DS Main Circuit Board Replacement, Back Panel: step 4, image 1 of 1
      • Remove the seven 6.4mm Y00 screws located on the back.
      • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
      Ask FixBot
    2. Nintendo DS Main Circuit Board Replacement: step 5, image 1 of 3 Nintendo DS Main Circuit Board Replacement: step 5, image 2 of 3 Nintendo DS Main Circuit Board Replacement: step 5, image 3 of 3
      • With your hands, pry the back panel off the main case.
      • Separate the back from the front, and set it aside.
      Ask FixBot
    1. Nintendo DS Main Circuit Board Replacement, Motherboard replacement.: step 6, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
      • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
      Ask FixBot
    2. Nintendo DS Main Circuit Board Replacement: step 7, image 1 of 3 Nintendo DS Main Circuit Board Replacement: step 7, image 2 of 3 Nintendo DS Main Circuit Board Replacement: step 7, image 3 of 3
      • Unlock the two large ribbon cables by moving the black clip up.
      • Carefully pull the ribbon cables down and out with your fingers.
      • Do not use pliers to pull the cables, as they can be damaged easily.
      Ask FixBot
    3. Nintendo DS Main Circuit Board Replacement: step 8, image 1 of 2 Nintendo DS Main Circuit Board Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
      • Slide the locks for the small ribbon cables down to the side, and remove the cables.
      • It may be useful to use tweezers to remove the small ribbon cables.
      • Be careful not to damage the delicate ribbon cables.
      Ask FixBot
    4. Nintendo DS Main Circuit Board Replacement: step 9, image 1 of 2 Nintendo DS Main Circuit Board Replacement: step 9, image 2 of 2
      • Locate the Wifi antenna pigtail connector.
      • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
      Ask FixBot
    5. Nintendo DS Main Circuit Board Replacement: step 10, image 1 of 1
      • Feed the ribbon cables through the opening on the board.
      • Pull up and remove the circuit board, and set it aside.
      Ask FixBot
24 other people completed this guide.
kingdesmond
2,261 Reputation
1 Guide authored
Cal Poly, Team 18-3, Maness Fall 2009 Member of Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Members
60 Guides authored
2 Guide Comments
This was really helpful. Thank you!
Jess Anderson - Reply Share
I need a ds ribbon bale ?
Shan Southern - Reply Share
Past 24 Hours: 10
Past 7 Days: 87
Past 30 Days: 348
All Time: 35,111
