Up to 20% off select tools
Nintendo DS Lite Trigger Buttons Replacement
Views: 65K
View statistics:
Past 24 Hours:
11
Past 7 Days:
98
Past 30 Days:
408
All Time:
64,584
Comments: 29
21 comments on steps, 8 guide comments.
Go to guide comments
Completed: 40
40 people have marked this guide "completed." Will you be next?
Favorites: 27
27 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Replace the trigger buttons on your Nintendo DS Lite and get back in the game!
    1. Nintendo DS Lite Trigger Buttons Replacement, Battery: step 1, image 1 of 2 Nintendo DS Lite Trigger Buttons Replacement, Battery: step 1, image 2 of 2
      • Unscrew the Phillips screw securing the battery cover to the lower case.
      • The screw remains captive to the battery cover.
      • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
      Ask FixBot
    2. Nintendo DS Lite Trigger Buttons Replacement: step 2, image 1 of 1
      • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
      • Remove the battery from the DS Lite.
      Ask FixBot
    1. Nintendo DS Lite Trigger Buttons Replacement, Lower Case: step 3, image 1 of 2 Nintendo DS Lite Trigger Buttons Replacement, Lower Case: step 3, image 2 of 2
      • Use the tip of a spudger to pry both rubber feet off the DS Lite.
      Ask FixBot
    2. Nintendo DS Lite Trigger Buttons Replacement: step 4, image 1 of 1
      • Remove the following screws securing the lower case to the body of the DS Lite:
      • Two 4.3 mm gold Phillips screws
      • One 3.9 mm black Tri-point screw
      • One 3.3 mm silver Phillips screw
      • Three 5.5 mm silver Tri-point screws
      Ask FixBot
    3. Nintendo DS Lite Trigger Buttons Replacement: step 5, image 1 of 3 Nintendo DS Lite Trigger Buttons Replacement: step 5, image 2 of 3 Nintendo DS Lite Trigger Buttons Replacement: step 5, image 3 of 3
      • Remove the cover from the Game Pak slot before continuing.
      • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
      • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
      • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
      Ask FixBot
    4. Nintendo DS Lite Trigger Buttons Replacement: step 6, image 1 of 1
      • Lift the lower case away from the rest of the DS Lite.
      • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
      • When re-assembling, make sure that power switch and volume sliders are properly aligned with the switches on the motherboard.
      Ask FixBot
    1. Nintendo DS Lite Trigger Buttons Replacement, Trigger Buttons: step 7, image 1 of 2 Nintendo DS Lite Trigger Buttons Replacement, Trigger Buttons: step 7, image 2 of 2
      • Lift both trigger buttons out of the DS Lite.
      • The trigger buttons are held in very loosely by small metal pegs and springs. Don't lose track of these pieces.
      • The second picture shows the correct configuration of the trigger assembly for reassembly purposes.
      Ask FixBot
40 other people completed this guide.
Author
with
Matthew Newsom
43,302 Reputation
67 Guides authored
8 Guide Comments
no no no no no
seng - Reply Share
Thank you this helped a lot I can finnaly play Zelda and Mario Cart now
MattTheGamer 49 - Reply Share
Hi! I am attempting a trigger repair, but it seems the console was opened and worked on before I got my hands on it, and the switch for the trigger snapped off the board. I taped it to the board to test, and it still works. Is my best bet soldering the switch back to the motherboard? Or could I get away with superglue? (I've never soldered before, and this looks delicate)
Tamara Girodie - Reply Share
I would definitely solder it, usually, these triggers are the ones that get the most stress and dirt around them so superglue might not last that much. If you have a problem with the trigger still. You might want to check the video I uploaded, it is in Spanish, though. https://youtu.be/7GRzZh9ZdNM
spinomagnus - Reply Share
I dont get how removing them is supposed to fix it. it says you need no parts. someone explain
ur mom - Reply Share
Past 24 Hours: 11
Past 7 Days: 98
Past 30 Days: 408
All Time: 64,584
