Nintendo DS Lite Motherboard Replacement
    1. Nintendo DS Lite Motherboard Replacement, Battery: step 1, image 1 of 2 Nintendo DS Lite Motherboard Replacement, Battery: step 1, image 2 of 2
      • Unscrew the Phillips screw securing the battery cover to the lower case.
      • The screw remains captive to the battery cover.
      • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
      Ask FixBot
    2. Nintendo DS Lite Motherboard Replacement: step 2, image 1 of 1
      • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
      • Remove the battery from the DS Lite.
      Ask FixBot
    1. Nintendo DS Lite Motherboard Replacement, Lower Case: step 3, image 1 of 2 Nintendo DS Lite Motherboard Replacement, Lower Case: step 3, image 2 of 2
      • Use the tip of a spudger to pry both rubber feet off the DS Lite.
      Ask FixBot
    2. Nintendo DS Lite Motherboard Replacement: step 4, image 1 of 1
      • Remove the following screws securing the lower case to the body of the DS Lite:
      • Two 4.3 mm gold Phillips screws
      • One 3.9 mm black Tri-point screw
      • One 3.3 mm silver Phillips screw
      • Three 5.5 mm silver Tri-point screws
      Ask FixBot
    3. Nintendo DS Lite Motherboard Replacement: step 5, image 1 of 3 Nintendo DS Lite Motherboard Replacement: step 5, image 2 of 3 Nintendo DS Lite Motherboard Replacement: step 5, image 3 of 3
      • Remove the cover from the Game Pak slot before continuing.
      • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
      • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
      • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
      Ask FixBot
    4. Nintendo DS Lite Motherboard Replacement: step 6, image 1 of 1
      • Lift the lower case away from the rest of the DS Lite.
      • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
      • When re-assembling, make sure that power switch and volume sliders are properly aligned with the switches on the motherboard.
      Ask FixBot
    1. Nintendo DS Lite Motherboard Replacement, Trigger Buttons: step 7, image 1 of 2 Nintendo DS Lite Motherboard Replacement, Trigger Buttons: step 7, image 2 of 2
      • Lift both trigger buttons out of the DS Lite.
      • The trigger buttons are held in very loosely by small metal pegs and springs. Don't lose track of these pieces.
      • The second picture shows the correct configuration of the trigger assembly for reassembly purposes.
      Ask FixBot
    1. Nintendo DS Lite Motherboard Replacement, Wi-Fi Board: step 8, image 1 of 1
      • Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
      Ask FixBot
    2. Nintendo DS Lite Motherboard Replacement: step 9, image 1 of 1
      • Use the flat edge of a spudger to pry the Wi-Fi board connector straight up from its socket on the motherboard.
      Ask FixBot
    3. Nintendo DS Lite Motherboard Replacement: step 10, image 1 of 1
      • Use the flat edge of a spudger to separate the right edge of the Wi-Fi board from the motherboard.
      • The Wi-Fi board is secured to the motherboard with a layer of adhesive.
      • Remove the Wi-Fi board from the DS Lite.
      Ask FixBot
    1. Nintendo DS Lite Motherboard Replacement, Motherboard: step 11, image 1 of 1
      • Use the flat edge of a spudger to pry the microphone connector straight up from its socket on the motherboard.
      Ask FixBot
    2. Nintendo DS Lite Motherboard Replacement: step 12, image 1 of 3 Nintendo DS Lite Motherboard Replacement: step 12, image 2 of 3 Nintendo DS Lite Motherboard Replacement: step 12, image 3 of 3
      • In the following steps you must pull the antenna cable between the DS Lite game cartridge reader and motherboard. Pull slowly and stop when you feel resistance to avoid damaging the cable or motherboard.
      • Position the antenna cable with its connector facing up and away from the motherboard using a spudger to hold it down lightly in the gap between chips on the motherboard.
      • Slowly and carefully pull the antenna cable until the cable connector is under the DS Lite game cartridge reader.
      • Continue pulling the cable until the cable connector comes out from under the game cartridge reader on the right side.
      • When reassembling and attempting to feed the antenna cable back under the game cartridge reader, the cable may kink or become difficult to feed through. If so, try feeding a piece of thread through first; then, tie the thread to one end of the cable connector and pull it through, guiding it past any obstructions.
      Ask FixBot
    3. Nintendo DS Lite Motherboard Replacement: step 13, image 1 of 2 Nintendo DS Lite Motherboard Replacement: step 13, image 2 of 2
      • Use your fingernail or the edge of a spudger to carefully flip up the touchscreen ribbon cable retaining flap.
      • Make sure you are flipping up the retaining flap, not the socket itself.
      • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
      • Do not lift the flap more than 90 degrees, or you will break it off.
      Ask FixBot
    4. Nintendo DS Lite Motherboard Replacement: step 14, image 1 of 1
      • Remove the two 3.4 mm Phillips screws securing the motherboard to the upper case.
      Ask FixBot
    5. Nintendo DS Lite Motherboard Replacement: step 15, image 1 of 1
      • Open the display enough to use your finger to push the front edge of the motherboard up and away from the upper case.
      • Do not try to remove the motherboard, as it is still connected to the upper display via the upper LCD ribbon cable.
      Ask FixBot
    6. Nintendo DS Lite Motherboard Replacement: step 16, image 1 of 2 Nintendo DS Lite Motherboard Replacement: step 16, image 2 of 2
      • Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap.
      • Pull the motherboard away from the DS Lite to separate the upper LCD ribbon cable from its socket on the motherboard.
      • Remove the motherboard from the DS Lite.
      • Now you may open the retaining flap for the lower LCD screen in the same way and separate the lower LCD screen from the motherboard.
      Ask FixBot
    1. Nintendo DS Lite Motherboard Replacement, Motherboard: step 17, image 1 of 1
      • Motherboard remains.
      Ask FixBot
76 other people completed this guide.
Matthew Newsom
42,939 Reputation
67 Guides authored
9 Guide Comments
Hey I took my do lite apart to repair the mic but then I saw that it would be risky do I put it back to tether carefully and now when it turns in the bottom LCD screen flickers then shuts down after the two speakers make a tiny pop sound, I did plug the top LCD screen cable back in but now I'm sad cause it's my first ever do before my 3ds, please help
Elemental__Owl - Reply Share
Just checking but did you make sure to reinsert the tiny ribbon cable from step 13? might be something tiny you overlooked?
enekuda - Reply Share
Is there any way to replace the socket for the touch screen? I bought a used DS lite with a non working screen and when I opened it I found out that the flap was broken
Juan Carlos Ramirez Chegue - Reply Share
Hi, I was trying this and everything works, but my left trigger button on the motherboard came off. I tried resoldering it and test it and it works… too well. As in it's constantly being pressed on, or it's registering constant button presses, even though it's not being pressed on. When I resoldered it, it only had 2 metal contact pins at the bottom. If I can get help for this as soon as possible, the repair will be complete.
Andres Guerrero Maldonado - Reply Share
The “microphone connector" is actually the digitizer ribbon, the microphone runs through the same cable as the top screen. Just a minor thing I wanted to point out.
[deleted] - Reply Share
Past 24 Hours: 32
Past 7 Days: 246
Past 30 Days: 979
All Time: 146,760
