Up to 20% off select tools
Nintendo DS Lite Disassembly
Views: 201K
View statistics:
Past 24 Hours:
88
Past 7 Days:
704
Past 30 Days:
3,172
All Time:
200,672
Comments: 55
37 comments on steps, 18 guide comments.
Go to guide comments
Completed: 78
78 people have marked this guide "completed." Will you be next?
Favorites: 28
28 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes
Difficulty: Difficult
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
I decided to teach myself how to repair Nintendo DS Lites, because broken units were available cheaply on eBay in 2017. After working on a few dozen units, I have seen the mistakes that people have made and I offer you this guide to make sure that you don't damage the unit that you're repairing (especially if you're fixing it for yourself). All of the problems I've seen with the DS Lite can be fixed for between $2 if you only need a new digitizer to about $10 if you need to obtain a used motherboard from an otherwise scrapped unit (2017 prices). Prices have risen since 2017 but repairing DS Lites is still reasonably economical.
Once you've learned how to disassemble the DS Lite, you should be able to tackle any Nintendo handheld, including the GameBoy, GameBoy Color, GameBoy Advance, DS, DSi, DSi XL, 3DS, 3DS XL, New 3DS XL, Switch, and Switch Lite. I have personally used these techniques to tear down all of these consoles with great success, and occasionally run an eBay store where I resell my repaired consoles.
WARNING: Do not attempt to disassemble any electronics device while the battery is connected (should be impossible for the DS Lite) or a power cable is connected.
    1. Nintendo DS Lite Disassembly, Introduction: step 1, image 1 of 1
      • The most common problem with the Nintendo DS Lite is a broken latch. You can buy a new shell for under $10 directly from China (2017 prices).
      Ask FixBot
    2. Nintendo DS Lite Disassembly, Remove the battery: step 2, image 1 of 3 Nintendo DS Lite Disassembly, Remove the battery: step 2, image 2 of 3 Nintendo DS Lite Disassembly, Remove the battery: step 2, image 3 of 3
      • Unscrew the battery case with a PH000 bit. You will probably need to pry open the battery case as the cover becomes sticky with age. The battery compartment is often quite tight so you might need to gently pry out the battery with the plastic spudger.
      Ask FixBot
    3. Nintendo DS Lite Disassembly, Remove the rubber feet: step 3, image 1 of 3 Nintendo DS Lite Disassembly, Remove the rubber feet: step 3, image 2 of 3 Nintendo DS Lite Disassembly, Remove the rubber feet: step 3, image 3 of 3
      • Quite commonly I see this part of the DS Lite damaged. Follow these steps to remove the feet without damaging anything.
      • To remove the rubber feet without damaging them, you can use a cotton swab soaked in isopropyl alcohol and press it lightly while making circle movements. This will help the glue come off.
      • For reassembling, you can reuse the same cotton swab, re-imbibing it with isopropyl alcohol to clean the part of the rubber feet with the glue, then putting it back where it belongs by pressing it down with your finger for a few minutes. the time it takes for the alcohol to evaporate and for the glue to regain its function.
      Ask FixBot
    4. Nintendo DS Lite Disassembly, Remove screws: step 4, image 1 of 1
      • Now remove the two gold colored screws under the rubber feet and the two silver colored screws in the battery compartment with the PH000 bit. Then remove the three silver screws and the small black screw with the Y00 bit. Set the Y00 bit aside as you are done using it.
      • The small black screw is hidden just here.
      Ask FixBot
    5. Nintendo DS Lite Disassembly, Remove the bottom cover: step 5, image 1 of 2 Nintendo DS Lite Disassembly, Remove the bottom cover: step 5, image 2 of 2
      • I see a lot of damage caused by carelessly removing the bottom cover, so take your time and carefully move the plastic spudger around the perimeter. If the bottom cover seems glued on, remove the cover with the unit closed. This may help prevent scratching the digitizer.
      Ask FixBot
    6. Nintendo DS Lite Disassembly, Remove the shoulder buttons: step 6, image 1 of 2 Nintendo DS Lite Disassembly, Remove the shoulder buttons: step 6, image 2 of 2
      • Carefully grasp and remove the shoulder buttons. Try to hold the spring assembly together so that you don't lose any pieces. The spring wire can puncture your skin so exercise caution. Wear safety glasses to avoid any rogue springs!
      Ask FixBot
    7. Nintendo DS Lite Disassembly, Remove the Wi-Fi daughterboard: step 7, image 1 of 2 Nintendo DS Lite Disassembly, Remove the Wi-Fi daughterboard: step 7, image 2 of 2
      • You must remove the Wi-Fi daughterboard at this stage or you risk damaging the digitizer. I learned this the hard way. You will need to pull hard on the daughterboard as the adhesive is very strong. You can try using heat or alcohol could to loosen the daughterboard, but that could risk damage to the components and I've never needed to do it.
      Ask FixBot
    8. Nintendo DS Lite Disassembly, Lift the digitizer flex connector: step 8, image 1 of 2 Nintendo DS Lite Disassembly, Lift the digitizer flex connector: step 8, image 2 of 2
      • Gently lift the digitizer flex connector from this side with a small flathead bit. Take your time and be gentle as this connector is easily broken. Replacing the digitizer is an extremely common repair for this console so I highly recommend learning how to do this.
      Ask FixBot
    9. Nintendo DS Lite Disassembly, Remove this screw: step 9, image 1 of 1
      • Remove the final screw holding down the motherboard.
      Ask FixBot
    10. Nintendo DS Lite Disassembly, Flip the motheboard around: step 10, image 1 of 3 Nintendo DS Lite Disassembly, Flip the motheboard around: step 10, image 2 of 3 Nintendo DS Lite Disassembly, Flip the motheboard around: step 10, image 3 of 3
      • Flip the motherboard around as shown. Be gentle as the flex cable is fragile. Note the Chinese writing on the console made at the Nintendo factory.
      Ask FixBot
    11. Nintendo DS Lite Disassembly, Remove the flex cable: step 11, image 1 of 1
      • Remove the flex cable with your fingernail. Do not use a flathead bit, as it may damage the connector. Sorry about the blurry picture, but this step will be obvious if you've been following along with a real unit. See the previous step for a clearer picture.
      Ask FixBot
    12. Nintendo DS Lite Disassembly, Remove black wire: step 12, image 1 of 1
      • Remove this black wire. You will have to wiggle it out. One of the stupidest design decisions on the DS Lite besides the latch problem, the black wire is even harder to put back in. Do not attempt to mess with the DS cartridge port in any way. With persistence, the black wire will come out and it will go back in when the time comes.
      Ask FixBot
    13. Nintendo DS Lite Disassembly, Remove white wire, digitizer flex: step 13, image 1 of 1
      • Make note of how the white wire is routed. You will need to replicate this routing for the reassembly. Now remove the white wire. Make sure that the digitizer flex cable was detached earlier. If not, go back and perform this step.
      Ask FixBot
    14. Nintendo DS Lite Disassembly, Remove the lower display: step 14, image 1 of 1
      • Remove the lower display flex connector. Pry the clip up with your fingernail, as you did with the upper display.
      Ask FixBot
    15. Nintendo DS Lite Disassembly, Remove button assemblies: step 15, image 1 of 2 Nintendo DS Lite Disassembly, Remove button assemblies: step 15, image 2 of 2
      • Remove the rubber and plastic button assemblies. This step is pretty easy, but don't lose any pieces. Every plastic and rubber piece can immediately go into hot, soapy water. Replace any rubber piece that is torn or excessively damaged.
      Ask FixBot
    16. Nintendo DS Lite Disassembly, Disassemble the latch: step 16, image 1 of 2 Nintendo DS Lite Disassembly, Disassemble the latch: step 16, image 2 of 2
      • This is the chief design flaw of the Nintendo DS Lite. The latch assembly is much too fragile. Save the screws and the metal and plastic piece if you're replacing the shell.
      Ask FixBot
    17. Nintendo DS Lite Disassembly, Note the white wire routing: step 17, image 1 of 1
      • The most common reason why DS Lites don't go together properly is that this white wire is not routed properly. When reassembling, follow this routing scheme and the finished product will feel like it is fresh off the factory floor.
      Ask FixBot
    18. Nintendo DS Lite Disassembly, Carefully separate the upper section: step 18, image 1 of 2 Nintendo DS Lite Disassembly, Carefully separate the upper section: step 18, image 2 of 2
      • Make sure that both wires are routed through the center of the flex cable and carefully route the flex cable through the slit. The flex cable is incredibly fragile, and it was strengthened in later models. Take your time on this step. If it takes you ten minutes to avoid damaging the flex cable, so be it.
      Ask FixBot
    19. Nintendo DS Lite Disassembly, Remove upper screws: step 19, image 1 of 3 Nintendo DS Lite Disassembly, Remove upper screws: step 19, image 2 of 3 Nintendo DS Lite Disassembly, Remove upper screws: step 19, image 3 of 3
      • With the smallest flathead bit you can find, work the bit under the sticker to avoid damaging the unit as much as possible. Slightly marring the ABS plastic is nearly impossible. I've had luck more recently using a plastic razor blade.
      • Same advice as for the rubber feet so to not damage them, you can use a cotton swab soaked in isopropyl alcohol and press it lightly while making circle movements. This will help the glue come off.
      Ask FixBot
    20. Nintendo DS Lite Disassembly, Pry the top cover loose: step 20, image 1 of 2 Nintendo DS Lite Disassembly, Pry the top cover loose: step 20, image 2 of 2
      • With the plastic spudger, pry the top cover loose. Do not remove or otherwise mess with the rubber pieces on the side. You never need to touch those, and I've seen them unnecessarily damaged and missing countless times. As noted in the comments, the screen will slide down a millimeter or two, allowing the pieces to separate easily.
      Ask FixBot
    21. Nintendo DS Lite Disassembly, Remove the top screen: step 21, image 1 of 2 Nintendo DS Lite Disassembly, Remove the top screen: step 21, image 2 of 2
      • Begin pressing on the top screen as show here and work your way around. Be fairly gentle but note that the actual LCD is protected by a plastic shield in front and a metal shield in back.
      Ask FixBot
    22. Nintendo DS Lite Disassembly, Remove mic and Wi-Fi antenna: step 22, image 1 of 3 Nintendo DS Lite Disassembly, Remove mic and Wi-Fi antenna: step 22, image 2 of 3 Nintendo DS Lite Disassembly, Remove mic and Wi-Fi antenna: step 22, image 3 of 3
      • Noting the routing of the black and white wires for later reassembly, remove the microphone and Wi-Fi antenna, carefully pulling the wires through the center of the flex cable so as not to cause any damage.
      Ask FixBot
    23. Nintendo DS Lite Disassembly, Speaker things: step 23, image 1 of 1
      • These should be removed and replaced shiny side up. They may be attached here or attached to the speakers.
      Ask FixBot
    24. Nintendo DS Lite Disassembly, Carefully remove the flex cable: step 24, image 1 of 3 Nintendo DS Lite Disassembly, Carefully remove the flex cable: step 24, image 2 of 3 Nintendo DS Lite Disassembly, Carefully remove the flex cable: step 24, image 3 of 3
      • If the flex cable is damaged, then you're out about $8 as of this writing. Exercise extreme caution with this fragile piece, carefully rolling it into a tight cylinder. If the flex cable is damaged, there is no way to repair the LCD, and the entire module must be scrapped. Remove and set aside the metal piece.
      Ask FixBot
    25. Nintendo DS Lite Disassembly, Finish shell disassembly: step 25, image 1 of 3 Nintendo DS Lite Disassembly, Finish shell disassembly: step 25, image 2 of 3 Nintendo DS Lite Disassembly, Finish shell disassembly: step 25, image 3 of 3
      • Remove three gold screws from the stylus retainer and two gold screws from the metal shield. Disassemble. You will need to gently pry loose the power switch and volume control. Wash all shell plastic pieces shown in hot, soapy water. Alcohol may be required to remove decals and other grime.
      Ask FixBot
    26. Nintendo DS Lite Disassembly, Remove sticker: step 26, image 1 of 3 Nintendo DS Lite Disassembly, Remove sticker: step 26, image 2 of 3 Nintendo DS Lite Disassembly, Remove sticker: step 26, image 3 of 3
      • If you're replacing the shell with a different color, you definitely need to remove the sticker. With the iFixit metal spudger, this step is easy.
      Ask FixBot
    27. Nintendo DS Lite Disassembly, Remove digitizer: step 27, image 1 of 3 Nintendo DS Lite Disassembly, Remove digitizer: step 27, image 2 of 3 Nintendo DS Lite Disassembly, Remove digitizer: step 27, image 3 of 3
      • Slide the metal spudger under the black sticker and carefully work your way around the assembly, avoiding the flex cables. This step is easier than it looks, but only perform this step if the screen or the digitizer needs to be replaced. If both are functional, this step is unnecessary. Thoroughly clean both pieces with alcohol afterwards.
      Ask FixBot
    28. Nintendo DS Lite Disassembly, Remove speakers: step 28, image 1 of 3 Nintendo DS Lite Disassembly, Remove speakers: step 28, image 2 of 3 Nintendo DS Lite Disassembly, Remove speakers: step 28, image 3 of 3
      • This step is only necessary if your upper LCD is bad. Unfortunately, this is a common problem. First, wet the contacts with flux. Then melt the solder and remove all four wires, noting their positions for reassembly. It might help to use leaded solder, but be sure to obey all local laws.
      Ask FixBot
    29. Nintendo DS Lite Disassembly, Clean flex contacts: step 29, image 1 of 2 Nintendo DS Lite Disassembly, Clean flex contacts: step 29, image 2 of 2
      • Clean up the contacts as you prefer. I use a tiny American-made solder wick and I've applied some fresh lead-based solder.
      Ask FixBot
    30. Nintendo DS Lite Disassembly, Inspect flex cable: step 30, image 1 of 1
      • Inspect the flex cable for damage.
      Ask FixBot
    31. Nintendo DS Lite Disassembly, Remove plastic cover: step 31, image 1 of 3 Nintendo DS Lite Disassembly, Remove plastic cover: step 31, image 2 of 3 Nintendo DS Lite Disassembly, Remove plastic cover: step 31, image 3 of 3
      • The plastic cover is wedged underneath the back metal cover and is held on by a few different schemes, depending upon how old the DS Lite is. One method is two tabs on each side. Gently work the tabs loose without removing the back metal cover. This step is unnecessary unless you're changing the color of the shell.
      Ask FixBot
    32. Nintendo DS Lite Disassembly, Test disassembled unit: step 32, image 1 of 2 Nintendo DS Lite Disassembly, Test disassembled unit: step 32, image 2 of 2
      • Optional: Test the disassembled unit. First, connect the Wi-Fi daughterboard. Connect the two screens, excluding the digitizer. While holding the battery in place, turn on the unit. Be cautious if you have removed any insulating material and there is new exposed metal. It is possible to blow a fuse or cause worse damage.
      Ask FixBot
To reassemble your device:
1) Insure that the white wire is properly routed before remounting the motherboard.
2) Carefully reassemble the shoulder buttons. This takes practice.
3) Insure that the alignment of the power switch and volume controls are correct before replacing the bottom case. Incorrect alignment will damage the motherboard and you won't be able to turn on the unit anymore.
78 other people completed this guide.
Author
with
John Gotts
2,401 Reputation
1 Guide authored
18 Guide Comments
Great work pal! Congratulations.
Daniel Moraes - Reply Share
The best guide online for fixing the DS lite. Thanks a lot!
JohnJD - Reply Share
I find this very specific and helpful! I will favorite this guide, once i have every materials required… especially the soldering part in this guide. Far from what i know… The guide deserved the best credits as the author included the soldering heat meter! However, i do not understand why the 2nd/middle picture (from right to left) at Step 28…
Step 28; Removing the Speaker things.
Pictures: links, the picture on the machine says… 402, not 400. - Picture is from step 28.
This step is only necessary if your upper LCD is bad. Unfortunately, this is a common problem. First, wet the contacts with flux. Then, with your iron at 400 degrees C, melt the solder and remove all four wires. It might help to add fresh solder with lead. The lead-free solder used by Nintendo sucks.
Cedric Izquierdo - Reply Share
I usually do my soldering between 300 and 350C.  If you do a fair amount of soldering, pick up a knockoff Hakko FG-100 tip thermometer and then get the official sensors.  This will set you back around $50 total on Amazon, but considering that the official FG-100 is over $200, it’s a steal.  Anyway…check your iron for accuracy.  The key here is heat transfer.  Use the largest tip that fits in/on the pad.  A larger tip will retain heat better and will heat a larger area at once.  Now as posted above, add some fresh leaded solder to the joint.  This will help to lower the melting temperature of the rest of the solder.  Final tip is: Don’t forget the flux.  Flux is your friend.  You can never have too much flux.  Flux will save you from bad joints, burned parts, and a lot of swearing.  Get yourself some flux in liquid and paste form.  Clean up the excess when you’re done with the highest concentration isopropyl alcohol you can find.
Jack Hain - Reply Share
I am new to soldering, so i can’t say i am fair to soldering, but i am going to give it a try especially since my Nintendo DS Lite is way old and in need of fixs and therefore cant spend alot for the time being… but ill still buy it either way! Thanks for the help! reasons i am in need of it is good materials and parts is because i want it to be completely like new for myself.
Past 24 Hours: 88
Past 7 Days: 704
Past 30 Days: 3,172
All Time: 200,672
