Introduction
Go to step 1 ↓Has your DS Lite battery stopped providing the game time you deserve? Replace the battery to free yourself from the wall charger.
Unscrew the Phillips screw securing the battery cover to the lower case.
Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
54 other people completed this guide.
7 Guide Comments
Can you describe the type of screw and captive washer ?
@cornelparaschiv it’s a tri wing screw
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
While a very late reply, someone else may find this useful.
In short, no. Not at all. The DS Lite Battery I own (Original) Is listed as
USG-003
3.7v
1000 mAH
3.7 Wh
Where as the DSi battery I own (Again, an original straight from my console) is listed as:
TWL-003
3.7v
840 mAH
3.1 Wh
While the same voltage and a slight difference in capacity, the DSi Battery is slightly longer and slimmer in width to the DS/DS Lite Battery and you will need to find a battery suited for the DS/DS Lite you're using. Many places will sell these batteries but do your research as not all of these are created equal.
