Up to 20% off select tools
Nintendo DS Bottom LCD Screen Replacement
Views: 55K
View statistics:
Past 24 Hours:
12
Past 7 Days:
93
Past 30 Days:
492
All Time:
55,026
Comments: 16
14 comments on steps, 2 guide comments.
Go to guide comments
Completed: 26
26 people have marked this guide "completed." Will you be next?
Favorites: 20
20 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
After removing the circuit board, the bottom LCD screen can easily be removed from the Nintendo DS.
    1. Nintendo DS Bottom LCD Screen Replacement, Battery: step 1, image 1 of 3 Nintendo DS Bottom LCD Screen Replacement, Battery: step 1, image 2 of 3 Nintendo DS Bottom LCD Screen Replacement, Battery: step 1, image 3 of 3
      • Remove the cartridge from the console.
      • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
      • Remove the battery door.
      • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
      Ask FixBot
    2. Nintendo DS Bottom LCD Screen Replacement: step 2, image 1 of 1
      • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
      Ask FixBot
    3. Nintendo DS Bottom LCD Screen Replacement: step 3, image 1 of 1
      • Remove the battery from the Nintendo DS.
      Ask FixBot
    1. Nintendo DS Bottom LCD Screen Replacement, Back Panel: step 4, image 1 of 1
      • Remove the seven 6.4mm Y00 screws located on the back.
      • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
      Ask FixBot
    2. Nintendo DS Bottom LCD Screen Replacement: step 5, image 1 of 3 Nintendo DS Bottom LCD Screen Replacement: step 5, image 2 of 3 Nintendo DS Bottom LCD Screen Replacement: step 5, image 3 of 3
      • With your hands, pry the back panel off the main case.
      • Separate the back from the front, and set it aside.
      Ask FixBot
    1. Nintendo DS Bottom LCD Screen Replacement, Motherboard replacement.: step 6, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
      • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
      Ask FixBot
    2. Nintendo DS Bottom LCD Screen Replacement: step 7, image 1 of 3 Nintendo DS Bottom LCD Screen Replacement: step 7, image 2 of 3 Nintendo DS Bottom LCD Screen Replacement: step 7, image 3 of 3
      • Unlock the two large ribbon cables by moving the black clip up.
      • Carefully pull the ribbon cables down and out with your fingers.
      • Do not use pliers to pull the cables, as they can be damaged easily.
      Ask FixBot
    3. Nintendo DS Bottom LCD Screen Replacement: step 8, image 1 of 2 Nintendo DS Bottom LCD Screen Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
      • Slide the locks for the small ribbon cables down to the side, and remove the cables.
      • It may be useful to use tweezers to remove the small ribbon cables.
      • Be careful not to damage the delicate ribbon cables.
      Ask FixBot
    4. Nintendo DS Bottom LCD Screen Replacement: step 9, image 1 of 2 Nintendo DS Bottom LCD Screen Replacement: step 9, image 2 of 2
      • Locate the Wifi antenna pigtail connector.
      • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
      Ask FixBot
    5. Nintendo DS Bottom LCD Screen Replacement: step 10, image 1 of 1
      • Feed the ribbon cables through the opening on the board.
      • Pull up and remove the circuit board, and set it aside.
      Ask FixBot
    1. Nintendo DS Bottom LCD Screen Replacement, Bottom LCD Screen: step 11, image 1 of 2 Nintendo DS Bottom LCD Screen Replacement, Bottom LCD Screen: step 11, image 2 of 2
      • Peel off the black cushion foam on the bottom touch screen to expose the ribbon cable.
      • Gently lift the screen out of the base.
      Ask FixBot
26 other people completed this guide.
Author
with
dnguye26
802 Reputation
4 Guides authored
Cal Poly, Team 18-3, Maness Fall 2009 Member of Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Members
60 Guides authored
2 Guide Comments
I like it but add a step 12 maybe, to see how to put in a new screen.
Zackary Benton - Reply Share
Why was this unfinished guide published?
Or was it just mistitled?
"How to 'almost' remove the lower screen"
mgoerlich1990 - Reply Share
Past 24 Hours: 12
Past 7 Days: 93
Past 30 Days: 492
All Time: 55,026
