Up to 20% off select tools
Nintendo DS Back Panel Replacement
Views: 23K
View statistics:
Past 24 Hours:
6
Past 7 Days:
49
Past 30 Days:
265
All Time:
22,550
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Removing the back panel is simple, provided you have the correct screwdriver. Nintendo uses a special Tri-point bit for the case, be sure you have one of these before disassembling!
    1. Nintendo DS Back Panel Replacement, Battery: step 1, image 1 of 3 Nintendo DS Back Panel Replacement, Battery: step 1, image 2 of 3 Nintendo DS Back Panel Replacement, Battery: step 1, image 3 of 3
      • Remove the cartridge from the console.
      • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
      • Remove the battery door.
      • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
      Ask FixBot
    2. Nintendo DS Back Panel Replacement: step 2, image 1 of 1
      • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
      Ask FixBot
    3. Nintendo DS Back Panel Replacement: step 3, image 1 of 1
      • Remove the battery from the Nintendo DS.
      Ask FixBot
    1. Nintendo DS Back Panel Replacement, Back Panel: step 4, image 1 of 1
      • Remove the seven 6.4mm Y00 screws located on the back.
      • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
      Ask FixBot
    2. Nintendo DS Back Panel Replacement: step 5, image 1 of 3 Nintendo DS Back Panel Replacement: step 5, image 2 of 3 Nintendo DS Back Panel Replacement: step 5, image 3 of 3
      • With your hands, pry the back panel off the main case.
      • Separate the back from the front, and set it aside.
      Ask FixBot
20 other people completed this guide.
Author
with
dnguye26
802 Reputation
4 Guides authored
Cal Poly, Team 18-3, Maness Fall 2009 Member of Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Members
60 Guides authored
2 Guide Comments
Where do I get a nintendo DS gamepak?
Kayla Maison - Reply Share
Kayla Maison , a gamepak is simply a GBA game.
Bob - Reply Share
Past 24 Hours: 6
Past 7 Days: 49
Past 30 Days: 265
All Time: 22,550
