Up to 20% off select tools
Nintendo 64 Motherboard Replacement
Views: 74K
View statistics:
Past 24 Hours:
11
Past 7 Days:
68
Past 30 Days:
369
All Time:
73,711
Comments: 9
6 comments on steps, 3 guide comments.
Go to guide comments
Completed: 41
41 people have marked this guide "completed." Will you be next?
Favorites: 43
43 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide will show how to replace the Nintendo 64 motherboard.
    1. Nintendo 64 Motherboard Replacement, Top Cover: step 1, image 1 of 1
      • Remove the expansion pack cover by pushing in the tab and pulling out.
      Ask FixBot
    2. Nintendo 64 Motherboard Replacement: step 2, image 1 of 1
      • If your system uses a jumper pack, the same procedure applies to remove it.
      • A small spoon can be used in place of a spudger.
      • Lever the expansion pack out using a metal spudger.
      Ask FixBot
    3. Nintendo 64 Motherboard Replacement: step 3, image 1 of 1
      • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
      Ask FixBot
    4. Nintendo 64 Motherboard Replacement: step 4, image 1 of 1
      • Remove the two front feet of the N64.
      Ask FixBot
    5. Nintendo 64 Motherboard Replacement: step 5, image 1 of 1
      • Rotate to top side up and lift off top cover.
      Ask FixBot
    1. Nintendo 64 Motherboard Replacement, Metal Plate: step 6, image 1 of 2 Nintendo 64 Motherboard Replacement, Metal Plate: step 6, image 2 of 2
      • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
      Ask FixBot
    2. Nintendo 64 Motherboard Replacement: step 7, image 1 of 2 Nintendo 64 Motherboard Replacement: step 7, image 2 of 2
      • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
      Ask FixBot
    3. Nintendo 64 Motherboard Replacement: step 8, image 1 of 1
      • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
      Ask FixBot
    4. Nintendo 64 Motherboard Replacement: step 9, image 1 of 1
      • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
      Ask FixBot
    5. Nintendo 64 Motherboard Replacement: step 10, image 1 of 1
      • Remove the small metal bracket from the back of the expansion pack slot.
      Ask FixBot
    6. Nintendo 64 Motherboard Replacement: step 11, image 1 of 2 Nintendo 64 Motherboard Replacement: step 11, image 2 of 2
      • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
      Ask FixBot
    7. Nintendo 64 Motherboard Replacement: step 12, image 1 of 2 Nintendo 64 Motherboard Replacement: step 12, image 2 of 2
      • Remove the small metal bracket behind the expansion slot using the spudger.
      Ask FixBot
    8. Nintendo 64 Motherboard Replacement: step 13, image 1 of 2 Nintendo 64 Motherboard Replacement: step 13, image 2 of 2
      • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
      Ask FixBot
    9. Nintendo 64 Motherboard Replacement: step 14, image 1 of 1
      • Lift off and remove the metal plate as indicated in the example.
      Ask FixBot
    1. Nintendo 64 Motherboard Replacement, Motherboard: step 15, image 1 of 1
      • Remove the four screws indicated using the #1 Phillips screwdriver.
      Ask FixBot
    2. Nintendo 64 Motherboard Replacement, Motherboard removal: step 16, image 1 of 1
      • Lift up and remove the motherboard.
      Ask FixBot
41 other people completed this guide.
Author
with
tonymag28
2,324 Reputation
3 Guides authored
Cal Poly, Team 5-4, Regan Fall 2009 Member of Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Members
60 Guides authored
3 Guide Comments
4.2mm doesn't seem right. When I looked to purchase all I saw was 4.5mm and now that I have one in my hand it seems to fit very precisely on the screws on my N64.
negroslim - Reply Share
i got the second comment :whyy:
Sqwerks - Reply Share
What are the symptoms of a bad motherboard?
Jon - Reply Share
Past 24 Hours: 11
Past 7 Days: 68
Past 30 Days: 369
All Time: 73,711
