Nintendo 64 Metal Plate Replacement
Views: 14K
View statistics:
Past 24 Hours:
3
Past 7 Days:
29
Past 30 Days:
147
All Time:
13,582
Comments: 5
5 comments on steps.
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide shows how to remove the metal plate that covers the motherboard.
Tools
    1. Nintendo 64 Metal Plate Replacement, Top Cover: step 1, image 1 of 1
      • Remove the expansion pack cover by pushing in the tab and pulling out.
      Ask FixBot
    2. Nintendo 64 Metal Plate Replacement: step 2, image 1 of 1
      • If your system uses a jumper pack, the same procedure applies to remove it.
      • A small spoon can be used in place of a spudger.
      • Lever the expansion pack out using a metal spudger.
      Ask FixBot
    3. Nintendo 64 Metal Plate Replacement: step 3, image 1 of 1
      • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
      Ask FixBot
    4. Nintendo 64 Metal Plate Replacement: step 4, image 1 of 1
      • Remove the two front feet of the N64.
      Ask FixBot
    5. Nintendo 64 Metal Plate Replacement: step 5, image 1 of 1
      • Rotate to top side up and lift off top cover.
      Ask FixBot
    1. Nintendo 64 Metal Plate Replacement, Metal Plate: step 6, image 1 of 2 Nintendo 64 Metal Plate Replacement, Metal Plate: step 6, image 2 of 2
      • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
      Ask FixBot
    2. Nintendo 64 Metal Plate Replacement: step 7, image 1 of 2 Nintendo 64 Metal Plate Replacement: step 7, image 2 of 2
      • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
      Ask FixBot
    3. Nintendo 64 Metal Plate Replacement: step 8, image 1 of 1
      • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
      Ask FixBot
    4. Nintendo 64 Metal Plate Replacement: step 9, image 1 of 1
      • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
      Ask FixBot
    5. Nintendo 64 Metal Plate Replacement: step 10, image 1 of 1
      • Remove the small metal bracket from the back of the expansion pack slot.
      Ask FixBot
    6. Nintendo 64 Metal Plate Replacement: step 11, image 1 of 2 Nintendo 64 Metal Plate Replacement: step 11, image 2 of 2
      • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
      Ask FixBot
    7. Nintendo 64 Metal Plate Replacement: step 12, image 1 of 2 Nintendo 64 Metal Plate Replacement: step 12, image 2 of 2
      • Remove the small metal bracket behind the expansion slot using the spudger.
      Ask FixBot
    8. Nintendo 64 Metal Plate Replacement: step 13, image 1 of 2 Nintendo 64 Metal Plate Replacement: step 13, image 2 of 2
      • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
      Ask FixBot
    9. Nintendo 64 Metal Plate Replacement: step 14, image 1 of 1
      • Lift off and remove the metal plate as indicated in the example.
      Ask FixBot
6 other people completed this guide.
LisaF818
164 Reputation
1 Guide authored
Cal Poly, Team 5-4, Regan Fall 2009 Member of Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 147
All Time: 13,582
