Nintendo 64 Controller Joystick Repair
Views: 56K
View statistics:
Past 24 Hours:
5
Past 7 Days:
95
Past 30 Days:
536
All Time:
56,299
Comments: 10
2 comments on steps, 8 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This fix is necessary for the owners of N64 controllers when the joystick becomes too loose over time. If the joystick of a controller is loose, game play becomes difficult. Conditions for this fix include: a flat surface, plenty of light, and a method for keeping track of individual components of the controller. Practice caution when using the knife in this fix.
Tools
Video Overview
    1. Nintendo 64 Controller Joystick Repair, Nintendo 64 Controller Joystick Repair: step 1, image 1 of 1
      • Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
      • Remove the back panel from the controller.
      Ask FixBot
    2. Nintendo 64 Controller Joystick Repair: step 2, image 1 of 1
      • Detach the two wired connections from the small, white box.
      Ask FixBot
    3. Nintendo 64 Controller Joystick Repair: step 3, image 1 of 1
      • Remove the screws (4.8 mm Phillips head) from the back of the white joystick box.
      • Remove the back panel of the white joystick box.
      • There are many small plastic components loose in this box, so be careful not to lose these.
      Ask FixBot
    4. Nintendo 64 Controller Joystick Repair: step 4, image 1 of 1
      • Remove the screw (4.8 mm Philips head) from the back of the joystick box.
      • Remove the joystick box from the controller.
      Ask FixBot
    5. Nintendo 64 Controller Joystick Repair: step 5, image 1 of 1
      • Use a cleaning cloth to remove residue and dirt from any components.
      Ask FixBot
    6. Nintendo 64 Controller Joystick Repair: step 6, image 1 of 1
      • Free the small, white bowl from its connections to the controller.
      • Remember the order in which each piece was removed.
      Ask FixBot
    7. Nintendo 64 Controller Joystick Repair: step 7, image 1 of 1
      • Pinch off a small piece of epoxy and knead it in your hand until a uniform color is reached.
      Ask FixBot
    8. Nintendo 64 Controller Joystick Repair: step 8, image 1 of 1
      • Press the epoxy into the center of the bowl with your finger and add a drop of water into the bowl.
      Ask FixBot
    9. Nintendo 64 Controller Joystick Repair: step 9, image 1 of 1
      • Place a marble into the bowl and use a push-twist motion to form the epoxy into the shape of the bowl.
      • Excess epoxy will rise above the bowl.
      Ask FixBot
    10. Nintendo 64 Controller Joystick Repair: step 10, image 1 of 1
      • Cut the edges of the excess epoxy with the exacto knife.
      • Repeat steps 8 and 9 until no excess epoxy is left.
      Ask FixBot
    11. Nintendo 64 Controller Joystick Repair: step 11, image 1 of 1
      • Let the epoxy sit and dry for 30 minutes or until the epoxy is hardened.
      Ask FixBot
    12. Nintendo 64 Controller Joystick Repair: step 12, image 1 of 1
      • Add a small coat of grease on top of the epoxy with your applicator.
      Ask FixBot
    13. Nintendo 64 Controller Joystick Repair: step 13, image 1 of 1
      • Apply grease to the bottom of the joystick (the area circled in red)
      Ask FixBot
    14. Nintendo 64 Controller Joystick Repair: step 14, image 1 of 1
      • Reverse these steps to reassemble the controller.
      • You may want to test the joystick stiffness before reassembling the controller.
      Ask FixBot
The fix is now complete. Move the joystick to test the stiffness. If the joystick is still very loose, you may need to add more epoxy. If the joystick is too stiff, you may need to remove excess epoxy.
14 other people completed this guide.
Brittany Slindee
360 Reputation
1 Guide authored
8 Guide Comments
N64 Joystick Permanent Fix & Refurbish New Parts Cheap
https://youtu.be/IPXgVSyL_rI?t=24
John - Reply Share
Sadly, it is out of stock too frequently. I’d prefer fixing rather than replacing.
Javier Moe - Reply Share
What is the epoxy substance called exactly? I tried searching online but results all come back for JB-Weld coldweld bonding products.
chrisdeliz - Reply Share
It took me a while too to find what they're using. I'm pretty sure it's Epoxy Putty, it's used to patch and seal holes.
TheLittlePotato - Reply Share
JB-Weld does seem to sell most of what's available to buy, maybe their PlasticWeld one would be most appropriate.
Past 24 Hours: 5
Past 7 Days: 95
Past 30 Days: 536
All Time: 56,299
