Nintendo 3DS XL Microphone Replacement
Views: 16K
View statistics:
Past 24 Hours:
4
Past 7 Days:
61
Past 30 Days:
255
All Time:
16,375
Comments: 14
12 comments on steps, 2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Very difficult
Introduction
Go to step 1 ↓
Voice recognition not working? Screaming at your Nintendo 3DS XL in hopes the game will finally pick up your voice? This guide will take you through the steps necessary to install a new microphone to have you back playing your favorite games in no time.
Parts
Tools
    1. Nintendo 3DS XL Microphone Replacement, Remove the back cover screws: step 1, image 1 of 1
      • Use a JIS 00 screwdriver to loosen the 4.2 mm‑long screws on the top edge of the back cover.
      • The screws have locking washers that prevent the screws from falling out. Keep these in place.
      Ask FixBot
    2. Nintendo 3DS XL Microphone Replacement, Remove the back cover: step 2, image 1 of 2 Nintendo 3DS XL Microphone Replacement, Remove the back cover: step 2, image 2 of 2
      • Use a plastic opening tool to pry off the clips securing the back cover, starting at the top corners and working your way down.
      • Use your hands to keep the clips from reattaching.
      • Use your hands to remove the back cover.
      Ask FixBot
    3. Nintendo 3DS XL Microphone Replacement: step 3, image 1 of 3 Nintendo 3DS XL Microphone Replacement: step 3, image 2 of 3 Nintendo 3DS XL Microphone Replacement: step 3, image 3 of 3
      • Insert the plastic opening tool into the opening located on the right side of the battery.
      • Pry the battery out of its recess and remove it.
      Ask FixBot
    1. Nintendo 3DS XL Microphone Replacement, Microphone: step 4, image 1 of 2 Nintendo 3DS XL Microphone Replacement, Microphone: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
      Ask FixBot
    2. Nintendo 3DS XL Microphone Replacement: step 5, image 1 of 2 Nintendo 3DS XL Microphone Replacement: step 5, image 2 of 2
      • Remove the six 6.2 mm screws using a Phillips #000 screwdriver.
      Ask FixBot
    3. Nintendo 3DS XL Microphone Replacement: step 6, image 1 of 1
      • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #000 screwdriver.
      Ask FixBot
    4. Nintendo 3DS XL Microphone Replacement: step 7, image 1 of 3 Nintendo 3DS XL Microphone Replacement: step 7, image 2 of 3 Nintendo 3DS XL Microphone Replacement: step 7, image 3 of 3
      • With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
      • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
      Ask FixBot
    5. Nintendo 3DS XL Microphone Replacement: step 8, image 1 of 3 Nintendo 3DS XL Microphone Replacement: step 8, image 2 of 3 Nintendo 3DS XL Microphone Replacement: step 8, image 3 of 3
      • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
      • Completely remove the lower case from the rest of the device and set aside.
      Ask FixBot
    6. Nintendo 3DS XL Microphone Replacement: step 9, image 1 of 3 Nintendo 3DS XL Microphone Replacement: step 9, image 2 of 3 Nintendo 3DS XL Microphone Replacement: step 9, image 3 of 3
      • Position the device such that the game cartridge slot is located at the top.
      • Locate the microphone in the bottom left corner.
      • Using tweezers remove the microphone.
      • There will be a ribbon that connects the microphone to the motherboard.
      Ask FixBot
    7. Nintendo 3DS XL Microphone Replacement: step 10, image 1 of 2 Nintendo 3DS XL Microphone Replacement: step 10, image 2 of 2
      • Using the flat head side of the spudger carefully lift up the flap and remove the ribbon.
      • The attached microphone can now be removed.
      Ask FixBot
6 other people completed this guide.
Charlene Donlon
11,322 Reputation
8 Guides authored
Cal Poly, Team 9-13, Regan Spring 2014 Member of Cal Poly, Team 9-13, Regan Spring 2014
CPSU-REGAN-S14S9G13
5 Members
96 Guides authored
2 Guide Comments
Hello! Do these instructions apply to the New 3DS XL as well? I followed steps from 1-8, but when I get to step 9, the layout is different and I can’t find the mic. Any help would be greatly appreciated!
Melissa Cardenas - Reply Share
please learn to repair the mic of new 3ds xl
andrew.hws - Reply Share
Past 24 Hours: 4
Past 7 Days: 61
Past 30 Days: 255
All Time: 16,375
