Nintendo 3DS XL Left Bumper Replacement
    1. Nintendo 3DS XL Left Bumper Replacement, Left Bumper: step 1, image 1 of 1
      • Remove the SD card and the game cartridge from the device.
      Ask FixBot
    2. Nintendo 3DS XL Left Bumper Replacement, Battery removal: step 2, image 1 of 2 Nintendo 3DS XL Left Bumper Replacement, Battery removal: step 2, image 2 of 2
      • Locate the battery cover panel on the back of the device.
      • Unscrew the two screws on the battery cover panel with a Phillips #00 screwdriver.
      • Remove the battery and battery cover panel.
      Ask FixBot
    3. Nintendo 3DS XL Left Bumper Replacement: step 3, image 1 of 1
      • Remove the four screws on the battery panel using the Phillips #00 screwdriver.
      Ask FixBot
    4. Nintendo 3DS XL Left Bumper Replacement: step 4, image 1 of 1
      • Locate the two screw covers on the bottom of the back panel, near the middle of the device.
      • These sticker-like covers are small, round, and made of rubber or plastic.
      • Insert the tip of a flathead screwdriver or spudger and gently pry the cover off by applying upward pressure.
      • You may need to wiggle the tool back and forth a bit to loosen the two covers.
      • Remove the two screws located behind the screw covers using a Phillips #00 screwdriver.
      Ask FixBot
    5. Nintendo 3DS XL Left Bumper Replacement: step 5, image 1 of 2 Nintendo 3DS XL Left Bumper Replacement: step 5, image 2 of 2
      • Remove the screw near the game card compartment using a Phillips #00 screwdriver.
      Ask FixBot
    6. Nintendo 3DS XL Left Bumper Replacement: step 6, image 1 of 2 Nintendo 3DS XL Left Bumper Replacement: step 6, image 2 of 2
      • Lift the back panel off of the device.
      • Be cautious not to pull any ribbons or cables from the motherboard as you remove the back panel.
      • Locate and disconnect the ribbon cables from the motherboard by gently pulling on the tabs that hold them in place.
      Ask FixBot
    7. Nintendo 3DS XL Left Bumper Replacement: step 7, image 1 of 2 Nintendo 3DS XL Left Bumper Replacement: step 7, image 2 of 2
      • Remove the three left bumper assembly screws using Phillips #00 screwdriver.
      • Once the three screws are removed, gently remove the left bumper assembly from the device.
      • The spring may eject from the assembly as you remove it.
      • Remove the hinge pin from the bumper assembly.
      Ask FixBot
    8. Nintendo 3DS XL Left Bumper Replacement: step 8, image 1 of 1
      • Separate the bumper from the bumper assembly
      Ask FixBot
    9. Nintendo 3DS XL Left Bumper Replacement: step 9, image 1 of 2 Nintendo 3DS XL Left Bumper Replacement: step 9, image 2 of 2
      Tool used on this step:
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • Using a spudger or a flathead screwdriver, gently pull the ribbon cable straight out of the connector in order to remove it.
      • The ribbon cable can be removed by other means such as using gloves or a microfiber cloth if preferred.
      • Replace the left bumper ribbon cable.
      Ask FixBot
6 other people completed this guide.
5 Guide Comments
No steps on how to install the new bumper?
Alex Tomalty - Reply Share
good but i wish there were reinstall instructions
Rowan Webb - Reply Share
I think that it's just basically do the steps backwards then you have it fixed.
Ender - Reply Share
Left bumper button turnes the game off when pressed. I have replaced the ribbon on the game any other suggestions.
Sean
Sean - Reply Share
my 3DS XL has a sticky right bumper - is the replacement procedure similar to the left? any major differences to be aware of? thanks in advance!
Gabby - Reply Share
Past 24 Hours: 8
Past 7 Days: 49
Past 30 Days: 323
All Time: 13,225
