Nintendo 3DS XL IR Board Replacement
    1. Nintendo 3DS XL IR Board Replacement, Remove the back cover screws: step 1, image 1 of 1
      • Use a JIS 00 screwdriver to loosen the 4.2 mm‑long screws on the top edge of the back cover.
      • The screws have locking washers that prevent the screws from falling out. Keep these in place.
      Ask FixBot
    2. Nintendo 3DS XL IR Board Replacement, Remove the back cover: step 2, image 1 of 2 Nintendo 3DS XL IR Board Replacement, Remove the back cover: step 2, image 2 of 2
      • Use a plastic opening tool to pry off the clips securing the back cover, starting at the top corners and working your way down.
      • Use your hands to keep the clips from reattaching.
      • Use your hands to remove the back cover.
      Ask FixBot
    3. Nintendo 3DS XL IR Board Replacement: step 3, image 1 of 3 Nintendo 3DS XL IR Board Replacement: step 3, image 2 of 3 Nintendo 3DS XL IR Board Replacement: step 3, image 3 of 3
      • Insert the plastic opening tool into the opening located on the right side of the battery.
      • Pry the battery out of its recess and remove it.
      Ask FixBot
    1. Nintendo 3DS XL IR Board Replacement, Circle Pad Joystick: step 4, image 1 of 2 Nintendo 3DS XL IR Board Replacement, Circle Pad Joystick: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
      Ask FixBot
    2. Nintendo 3DS XL IR Board Replacement: step 5, image 1 of 2 Nintendo 3DS XL IR Board Replacement: step 5, image 2 of 2
      • Remove the six 6.2 mm screws using a Phillips #00 screwdriver
      Ask FixBot
    3. Nintendo 3DS XL IR Board Replacement: step 6, image 1 of 1
      • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #00 screwdriver.
      Ask FixBot
    4. Nintendo 3DS XL IR Board Replacement: step 7, image 1 of 3 Nintendo 3DS XL IR Board Replacement: step 7, image 2 of 3 Nintendo 3DS XL IR Board Replacement: step 7, image 3 of 3
      • Make sure the SD card has been removed.
      • With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
      • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
      Ask FixBot
    5. Nintendo 3DS XL IR Board Replacement: step 8, image 1 of 3 Nintendo 3DS XL IR Board Replacement: step 8, image 2 of 3 Nintendo 3DS XL IR Board Replacement: step 8, image 3 of 3
      • Disconnect the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
      • Completely remove the lower case from the rest of the device and set aside.
      Ask FixBot
    6. Nintendo 3DS XL IR Board Replacement: step 9, image 1 of 2 Nintendo 3DS XL IR Board Replacement: step 9, image 2 of 2
      • Position the device such that the game cartridge slot is located at the top.
      • Locate the circle pad on the right side of the device.
      • Remove the two 7.5 mm screws on the upper left and the bottom right corners.
      Ask FixBot
    7. Nintendo 3DS XL IR Board Replacement: step 10, image 1 of 2 Nintendo 3DS XL IR Board Replacement: step 10, image 2 of 2
      • Using a plastic opening tool pop off the circle pad joystick.
      • Do not use excessive force with the plastic opening tool. There is a ribbon attaching the circle pad joystick to the motherboard that will remain attached.
      • There is a loose washer located in between the circle pad joystick and the circle pad. Use caution and do not lose this piece.
      Ask FixBot
    8. Nintendo 3DS XL IR Board Replacement: step 11, image 1 of 2 Nintendo 3DS XL IR Board Replacement: step 11, image 2 of 2
      • Using the flat head side of the spudger carefully lift up the retaining flap that attaches the circle pad ribbon to the motherboard.
      • Remove the ribbon and circle pad joystick.
      • To remove the circle pad joystick, remove the thin ring of plastic under the back of the circle pad, and set it aside. Then, rotate the pad to make it slip out.
      Ask FixBot
    1. Nintendo 3DS XL IR Board Replacement, IR Board: step 12, image 1 of 2 Nintendo 3DS XL IR Board Replacement, IR Board: step 12, image 2 of 2
      • Locate the IR board on the upper right side of the motherboard.
      • The IR board is installed upside-down in these photos by mistake. Installing it this way will result in your DS failing to start. Note the orientation of your IR board before you remove it, and reinstall it the same way.
      • Remove the IR board with a plastic opening tool by inserting the tool below the IR board and gently prying up.
      Ask FixBot
11 other people completed this guide.
Charlene Donlon
11,307 Reputation
8 Guides authored
Cal Poly, Team 9-13, Regan Spring 2014 Member of Cal Poly, Team 9-13, Regan Spring 2014
CPSU-REGAN-S14S9G13
5 Members
96 Guides authored
4 Guide Comments
This guide was really helpful, I had to teardown my 3DS to remove a rice crispy that was stuck in the SD card reader, I don't know how it got there, I wasn't even eating cereals
Tony The Tiger - Reply Share
was removing the analog stick really necessary?
8bitlooser - Reply Share
So I have an original 3DS and a 3DS XL the 3DS Xl Works great but the 3DS won't turn on. I believe it is because I t has a missing IR Board. I am hoping to use the one on the 3DS XL. Do you think it will work?they look similar in the pictures..... Anyway I am confused as to why I have to take out the cirlepad??
AppleTopic - Reply Share
if you are missing ir board the system will not boot?
Kostandinos Minas Talarantas - Reply Share
Past 24 Hours: 13
Past 7 Days: 84
Past 30 Days: 333
All Time: 25,262
