Nintendo 3DS XL Hinge/Midframe Replacement
    1. Nintendo 3DS XL Hinge/Midframe Replacement, Hinge/Midframe: step 1, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement, Hinge/Midframe: step 1, image 2 of 2
      • Flip the 3DS XL upside down.
      Ask FixBot
    2. Nintendo 3DS XL Hinge/Midframe Replacement: step 2, image 1 of 1
      • Remove the two 4.2 mm screws from the back cover using a Phillips #00 screwdriver.
      Ask FixBot
    3. Nintendo 3DS XL Hinge/Midframe Replacement: step 3, image 1 of 1
      • Use an opening tool to pry the cover loose and lift the back cover.
      • Caution: Make sure to lift the side with the screws up first as to not break hooks on the cover.
      Ask FixBot
    4. Nintendo 3DS XL Hinge/Midframe Replacement: step 4, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 4, image 2 of 2
      • Use an opening tool to remove the battery.
      Ask FixBot
    5. Nintendo 3DS XL Hinge/Midframe Replacement: step 5, image 1 of 1
      • Remove the six 6.2 mm screws from the back cover using a Phillips #00 screwdriver.
      • Remove the single 2.3 mm screw from the back cover using a Phillips #00 screwdriver.
      Ask FixBot
    6. Nintendo 3DS XL Hinge/Midframe Replacement: step 6, image 1 of 3 Nintendo 3DS XL Hinge/Midframe Replacement: step 6, image 2 of 3 Nintendo 3DS XL Hinge/Midframe Replacement: step 6, image 3 of 3
      • Use your hands to carefully remove the back cover at an angle, while keeping it connected to the top edge with caution regarding the ribbons.
      Ask FixBot
    7. Nintendo 3DS XL Hinge/Midframe Replacement: step 7, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to carefully detach both of the ribbon cables connected to the back cover.
      Ask FixBot
    8. Nintendo 3DS XL Hinge/Midframe Replacement: step 8, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 8, image 2 of 2
      • Remove the two 7.5 mm screws from the white plate.
      • Use your fingers to lift it off the space carefully.
      Ask FixBot
    9. Nintendo 3DS XL Hinge/Midframe Replacement: step 9, image 1 of 1
      • Use a pair of tweezers to remove the small plastic circle from the opened space.
      Ask FixBot
    10. Nintendo 3DS XL Hinge/Midframe Replacement: step 10, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 10, image 2 of 2
      • Use your fingers to carefully disconnect the small green rectangle (network board).
      Ask FixBot
    11. Nintendo 3DS XL Hinge/Midframe Replacement: step 11, image 1 of 1
      • Remove the ten 3 mm screws from the motherboard with a Phillips #00 screwdriver.
      Ask FixBot
    12. Nintendo 3DS XL Hinge/Midframe Replacement: step 12, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 12, image 2 of 2
      • On the bottom right corner, remove the small plastic piece using a pair of tweezers.
      Ask FixBot
    13. Nintendo 3DS XL Hinge/Midframe Replacement: step 13, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 13, image 2 of 2
      • On the bottom left corner, remove the small plastic piece using a pair of tweezers.
      Ask FixBot
    14. Nintendo 3DS XL Hinge/Midframe Replacement: step 14, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 14, image 2 of 2
      • With caution yet with slight force, use a pair of tweezers to pull and disconnect the ribbon cable from the latch on the top right corner.
      Ask FixBot
    15. Nintendo 3DS XL Hinge/Midframe Replacement: step 15, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 15, image 2 of 2
      • With caution yet with slight force, use a pair of tweezers to pull and disconnect the second ribbon cable from the latch on the top right corner.
      Ask FixBot
    16. Nintendo 3DS XL Hinge/Midframe Replacement: step 16, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 16, image 2 of 2
      • With caution yet with slight force, use your hands to lift the screen and the green motherboard from the frame.
      • Caution: There is still a ribbon cable connected, so do not suddenly remove what was lifted.
      Ask FixBot
    17. Nintendo 3DS XL Hinge/Midframe Replacement: step 17, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 17, image 2 of 2
      • With caution yet with slight force, use a pair of tweezers to pull and disconnect the ribbon cable at the hinge from the latch.
      Ask FixBot
    18. Nintendo 3DS XL Hinge/Midframe Replacement: step 18, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 18, image 2 of 2
      • Use your fingers to disconnect the green rectangle (network board) from the small green cable.
      Ask FixBot
    19. Nintendo 3DS XL Hinge/Midframe Replacement: step 19, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 19, image 2 of 2
      • Flip the 3DS XL right side up and open it.
      Ask FixBot
    20. Nintendo 3DS XL Hinge/Midframe Replacement: step 20, image 1 of 3 Nintendo 3DS XL Hinge/Midframe Replacement: step 20, image 2 of 3 Nintendo 3DS XL Hinge/Midframe Replacement: step 20, image 3 of 3
      • Use a pair of tweezers to remove the small rubber squares from each corner of the front screen.
      Ask FixBot
    21. Nintendo 3DS XL Hinge/Midframe Replacement: step 21, image 1 of 1
      • Remove the four 4.3 mm screws from the top screen using a Phillips #00 screwdriver.
      Ask FixBot
    22. Nintendo 3DS XL Hinge/Midframe Replacement: step 22, image 1 of 3 Nintendo 3DS XL Hinge/Midframe Replacement: step 22, image 2 of 3 Nintendo 3DS XL Hinge/Midframe Replacement: step 22, image 3 of 3
      • Use your hands to remove the top cover by pushing the cover horizontally away from the hinges, as to not break any plastic hooks.
      Ask FixBot
    23. Nintendo 3DS XL Hinge/Midframe Replacement: step 23, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 23, image 2 of 2
      • Flip the 3DS XL upside down and find the top left hinge.
      • In the small opening, use a small opening tool to push the small white plastic piece down towards the other hinge.
      • Caution: A decent amount of force will be needed to push it down, so use a small but sturdy object that can fit in the opening to push it down.
      Ask FixBot
    24. Nintendo 3DS XL Hinge/Midframe Replacement: step 24, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 24, image 2 of 2
      • Use a pair of tweezers to remove the small black plastic piece covering the hinge.
      Ask FixBot
    25. Nintendo 3DS XL Hinge/Midframe Replacement: step 25, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 25, image 2 of 2
      • Use a pair of tweezers to remove the small clear plastic piece from the hinge.
      • At this point you can remove the bottom frame from the left hinge using your hands.
      Ask FixBot
    26. Nintendo 3DS XL Hinge/Midframe Replacement: step 26, image 1 of 3 Nintendo 3DS XL Hinge/Midframe Replacement: step 26, image 2 of 3 Nintendo 3DS XL Hinge/Midframe Replacement: step 26, image 3 of 3
      • At the top right hinge, use your hands to carefully slide the ribbon cables through a small gap next to the hinge to remove them from the bottom frame.
      Ask FixBot
    27. Nintendo 3DS XL Hinge/Midframe Replacement: step 27, image 1 of 2 Nintendo 3DS XL Hinge/Midframe Replacement: step 27, image 2 of 2
      • Use your fingers to remove all buttons and rubber covers from the old frame and place them into the new frame.
      Ask FixBot
10 other people completed this guide.
FixitKevin
655 Reputation
1 Guide authored
4 Guide Comments
the photos leave a lot to be desired as I can't even see the small part that you take off to access the hinge itself unfortunately and now I am stuck with a completely taken apart 3ds lx that does not work without taking off the hinge.
Hailey Allen - Reply Share
I've found a video on YouTube that goes over hinge replacements. I'm also trying to fix and replace my 3DS shell and I've used this as a tutorial.
https://youtu.be/ulwjPQ_Ntro?si=zTl-Gxgw...
Also when looking up 3DS replacements and tutorials read the comments! People go over a lot of support and their own personal experiences and tips.
UnsungBee - Reply Share
I was wanging it violently last night but when i read this a brown tear ran down my leg :)
Mr. tough tip - Reply Share
why do you need to share this
Enn - Reply Share
Past 24 Hours: 64
Past 7 Days: 535
Past 30 Days: 2,285
All Time: 55,803
