Nintendo 3DS NFC Reader Motherboard Replacement
  1. Nintendo 3DS NFC Reader Motherboard Replacement, Motherboard: step 1, image 1 of 3 Nintendo 3DS NFC Reader Motherboard Replacement, Motherboard: step 1, image 2 of 3 Nintendo 3DS NFC Reader Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Flip the adapter so the bottom side faces up.
    • Remove the cover by pressing the plastic flap and lifting it up with one finger.
    Ask FixBot
  2. Nintendo 3DS NFC Reader Motherboard Replacement: step 2, image 1 of 3 Nintendo 3DS NFC Reader Motherboard Replacement: step 2, image 2 of 3 Nintendo 3DS NFC Reader Motherboard Replacement: step 2, image 3 of 3
    • Remove the batteries by pressing the positive side towards the negative side and lifting with one finger.
    Ask FixBot
  3. Nintendo 3DS NFC Reader Motherboard Replacement: step 3, image 1 of 3 Nintendo 3DS NFC Reader Motherboard Replacement: step 3, image 2 of 3 Nintendo 3DS NFC Reader Motherboard Replacement: step 3, image 3 of 3
    • Grab your tri-point screwdriver.
    • Locate the four holes containing the tri-point screws at each corner of the adapter.
    • Using the screwdriver, unscrew all four screws.
    • Put the screws out of the way.
    Ask FixBot
  4. Nintendo 3DS NFC Reader Motherboard Replacement: step 4, image 1 of 2 Nintendo 3DS NFC Reader Motherboard Replacement: step 4, image 2 of 2
    • After removing the screws, flip the adapter where the top side faces up.
    • Using your fingers, pull the top off of the adapter.
    • Place the top out of the way.
    Ask FixBot
  5. Nintendo 3DS NFC Reader Motherboard Replacement: step 5, image 1 of 2 Nintendo 3DS NFC Reader Motherboard Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Using your tweezers, remove the translucent plastic by lifting upwards out of it's peg.
    Ask FixBot
  6. Nintendo 3DS NFC Reader Motherboard Replacement: step 6, image 1 of 3 Nintendo 3DS NFC Reader Motherboard Replacement: step 6, image 2 of 3 Nintendo 3DS NFC Reader Motherboard Replacement: step 6, image 3 of 3
    • To remove the black slide, use your fingers to slide the black slide out of its slot.
    Ask FixBot
  7. Nintendo 3DS NFC Reader Motherboard Replacement: step 7, image 1 of 3 Nintendo 3DS NFC Reader Motherboard Replacement: step 7, image 2 of 3 Nintendo 3DS NFC Reader Motherboard Replacement: step 7, image 3 of 3
    • Using the tweezers, carefully lift up the plastic button out of its slot.
    Ask FixBot
  8. Nintendo 3DS NFC Reader Motherboard Replacement: step 8, image 1 of 3 Nintendo 3DS NFC Reader Motherboard Replacement: step 8, image 2 of 3 Nintendo 3DS NFC Reader Motherboard Replacement: step 8, image 3 of 3
    • Using your tweezers, carefully loosen the copper wire from its plastic holder.
    • Then with the tweezers, remove the plastic holding the motherboard in place.
    Ask FixBot
  9. Nintendo 3DS NFC Reader Motherboard Replacement: step 9, image 1 of 2 Nintendo 3DS NFC Reader Motherboard Replacement: step 9, image 2 of 2
    • Using your fingers, carefully lift the board and place it down, out of the way.
    Ask FixBot
Finish Line
Sruiz84
196 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 52
All Time: 1,081
