Nintendo 3DS 2015 SD Card Reader Replacement
    1. Nintendo 3DS 2015 SD Card Reader Replacement, Battery: step 1, image 1 of 1
      • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
      • The screws on the back panel strip easily. Go slowly and press down firmly.
      • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
      Ask FixBot
    2. Nintendo 3DS 2015 SD Card Reader Replacement: step 2, image 1 of 2 Nintendo 3DS 2015 SD Card Reader Replacement: step 2, image 2 of 2
      • Pull the top corner tabs of the front face plate outward and towards you.
      • Pull the faceplate up and out of the slots at the bottom of the device.
      • Set aside the back faceplate.
      Ask FixBot
    3. Nintendo 3DS 2015 SD Card Reader Replacement: step 3, image 1 of 3 Nintendo 3DS 2015 SD Card Reader Replacement: step 3, image 2 of 3 Nintendo 3DS 2015 SD Card Reader Replacement: step 3, image 3 of 3
      • Insert a plastic opening tool into the notch at the top of the battery.
      • Pry the battery up with the plastic opening tool.
      Ask FixBot
    1. Nintendo 3DS 2015 SD Card Reader Replacement, SD Card Reader: step 4, image 1 of 1
      • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
      • The bottom of the SD card reader should slightly pop out after removing the screws.
      Ask FixBot
    2. Nintendo 3DS 2015 SD Card Reader Replacement: step 5, image 1 of 1
      • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
      • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
      • Reorient the device so that the power jack faces you.
      Ask FixBot
    3. Nintendo 3DS 2015 SD Card Reader Replacement: step 6, image 1 of 2 Nintendo 3DS 2015 SD Card Reader Replacement: step 6, image 2 of 2
      • Lift the SD card reader gently.
      • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
      • Lift the SD card reader out off of the lower casing.
      Ask FixBot
5 other people completed this guide.
Tyler Starr
1,779 Reputation
7 Guides authored
Cal Poly, Team 4-6, Livingston Fall 2016 Member of Cal Poly, Team 4-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G6
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 53
Past 30 Days: 217
All Time: 9,774
