Nintendo 3DS 2015 D Pad Replacement
    1. Nintendo 3DS 2015 D Pad Replacement, Battery: step 1, image 1 of 1
      • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
      • The screws on the back panel strip easily. Go slowly and press down firmly.
      • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
      Ask FixBot
    2. Nintendo 3DS 2015 D Pad Replacement: step 2, image 1 of 2 Nintendo 3DS 2015 D Pad Replacement: step 2, image 2 of 2
      • Pull the top corner tabs of the front face plate outward and towards you.
      • Pull the faceplate up and out of the slots at the bottom of the device.
      • Set aside the back faceplate.
      Ask FixBot
    3. Nintendo 3DS 2015 D Pad Replacement: step 3, image 1 of 3 Nintendo 3DS 2015 D Pad Replacement: step 3, image 2 of 3 Nintendo 3DS 2015 D Pad Replacement: step 3, image 3 of 3
      • Insert a plastic opening tool into the notch at the top of the battery.
      • Pry the battery up with the plastic opening tool.
      Ask FixBot
    1. Nintendo 3DS 2015 D Pad Replacement, SD Card Reader: step 4, image 1 of 1
      • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
      • The bottom of the SD card reader should slightly pop out after removing the screws.
      Ask FixBot
    2. Nintendo 3DS 2015 D Pad Replacement: step 5, image 1 of 1
      • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
      • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
      • Reorient the device so that the power jack faces you.
      Ask FixBot
    3. Nintendo 3DS 2015 D Pad Replacement: step 6, image 1 of 2 Nintendo 3DS 2015 D Pad Replacement: step 6, image 2 of 2
      • Lift the SD card reader gently.
      • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
      • Lift the SD card reader out off of the lower casing.
      Ask FixBot
    1. Nintendo 3DS 2015 D Pad Replacement, Lower Case: step 7, image 1 of 3 Nintendo 3DS 2015 D Pad Replacement, Lower Case: step 7, image 2 of 3 Nintendo 3DS 2015 D Pad Replacement, Lower Case: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Reorient the device so that the game slot now faces you.
      • Remove the two rubber bumpers along the top of the device using tweezers.
      • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
      Ask FixBot
    2. Nintendo 3DS 2015 D Pad Replacement: step 8, image 1 of 2 Nintendo 3DS 2015 D Pad Replacement: step 8, image 2 of 2
      • Lift the top edge of the lower case slightly off on the 3DS.
      • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
      • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
      • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
      Ask FixBot
    3. Nintendo 3DS 2015 D Pad Replacement: step 9, image 1 of 3 Nintendo 3DS 2015 D Pad Replacement: step 9, image 2 of 3 Nintendo 3DS 2015 D Pad Replacement: step 9, image 3 of 3
      • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
      • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
      Ask FixBot
    1. Nintendo 3DS 2015 D Pad Replacement, Gamecard Reader: step 10, image 1 of 2 Nintendo 3DS 2015 D Pad Replacement, Gamecard Reader: step 10, image 2 of 2
      • Locate the gamecard reader near the bottom right corner of the motherboard.
      • Unscrew the four 3mm Phillips #00 screws along the edge of the gamecard reader.
      • Lift the black latch on the ZIF connector along the right side of the reader using a plastic opening tool.
      Ask FixBot
    2. Nintendo 3DS 2015 D Pad Replacement: step 11, image 1 of 2 Nintendo 3DS 2015 D Pad Replacement: step 11, image 2 of 2
      • Pry the ribbon cable from its socket, just left of the joystick, using the flat side of a spudger.
      • Grab the right edge of the gamecard reader and lift it out of the device, watching to make sure the ribbon cables don't snag.
      Ask FixBot
    1. Nintendo 3DS 2015 D Pad Replacement, D Pad: step 12, image 1 of 2 Nintendo 3DS 2015 D Pad Replacement, D Pad: step 12, image 2 of 2
      • Remove the four 3mm Phillips #00 screws from the four corners of the D pad board.
      • Lift the D pad board out of the device.
      Ask FixBot
    2. Nintendo 3DS 2015 D Pad Replacement: step 13, image 1 of 2 Nintendo 3DS 2015 D Pad Replacement: step 13, image 2 of 2
      Buy
      • Peel the rubber piece, backing the D pad, out of the device.
      • Lift the D pad out of the device with a pair of tweezers.
      Ask FixBot
Tyler Starr
1,779 Reputation
7 Guides authored
Cal Poly, Team 4-6, Livingston Fall 2016 Member of Cal Poly, Team 4-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G6
4 Members
108 Guides authored
4 Guide Comments
I think you missed a few steps after step 9. There is no mention of removing the 3DS Cartridge reader or Circle Pad.
jharris - Reply Share
Jharris is right
Birby B. - Reply Share
Thanks for pointing that out! I think it is fixed now.
-Tyler
Tyler Starr - Reply Share
My new 3DS d-pad is stuck in the up direction, what could be the problem?
Flute_Boi - Reply Share
Past 24 Hours: 3
Past 7 Days: 47
Past 30 Days: 158
All Time: 6,822
