Nintendo 3DS 2015 Circle Pad Replacement
    1. Nintendo 3DS 2015 Circle Pad Replacement, Battery: step 1, image 1 of 1
      • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
      • The screws on the back panel strip easily. Go slowly and press down firmly.
      • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
      Ask FixBot
    2. Nintendo 3DS 2015 Circle Pad Replacement: step 2, image 1 of 2 Nintendo 3DS 2015 Circle Pad Replacement: step 2, image 2 of 2
      • Pull the top corner tabs of the front face plate outward and towards you.
      • Pull the faceplate up and out of the slots at the bottom of the device.
      • Set aside the back faceplate.
      Ask FixBot
    3. Nintendo 3DS 2015 Circle Pad Replacement: step 3, image 1 of 3 Nintendo 3DS 2015 Circle Pad Replacement: step 3, image 2 of 3 Nintendo 3DS 2015 Circle Pad Replacement: step 3, image 3 of 3
      • Insert a plastic opening tool into the notch at the top of the battery.
      • Pry the battery up with the plastic opening tool.
      Ask FixBot
    1. Nintendo 3DS 2015 Circle Pad Replacement, SD Card Reader: step 4, image 1 of 1
      • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
      • The bottom of the SD card reader should slightly pop out after removing the screws.
      Ask FixBot
    2. Nintendo 3DS 2015 Circle Pad Replacement: step 5, image 1 of 1
      • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
      • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
      • Reorient the device so that the power jack faces you.
      Ask FixBot
    3. Nintendo 3DS 2015 Circle Pad Replacement: step 6, image 1 of 2 Nintendo 3DS 2015 Circle Pad Replacement: step 6, image 2 of 2
      • Lift the SD card reader gently.
      • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
      • Lift the SD card reader out off of the lower casing.
      Ask FixBot
    1. Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: step 7, image 1 of 3 Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: step 7, image 2 of 3 Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Reorient the device so that the game slot now faces you.
      • Remove the two rubber bumpers along the top of the device using tweezers.
      • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
      Ask FixBot
    2. Nintendo 3DS 2015 Circle Pad Replacement: step 8, image 1 of 2 Nintendo 3DS 2015 Circle Pad Replacement: step 8, image 2 of 2
      • Lift the top edge of the lower case slightly off on the 3DS.
      • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
      • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
      • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
      Ask FixBot
    3. Nintendo 3DS 2015 Circle Pad Replacement: step 9, image 1 of 3 Nintendo 3DS 2015 Circle Pad Replacement: step 9, image 2 of 3 Nintendo 3DS 2015 Circle Pad Replacement: step 9, image 3 of 3
      • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
      • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
      Ask FixBot
    1. Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: step 10, image 1 of 3 Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: step 10, image 2 of 3 Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: step 10, image 3 of 3
      • Locate the joystick assembly near the top right corner of the motherboard.
      • Remove the two 8mm Phillips #00 screws from the back of the joystick.
      • Use the flat end of the spudger to pry off the joystick pad from its plastic housing.
      Ask FixBot
    2. Nintendo 3DS 2015 Circle Pad Replacement: step 11, image 1 of 2 Nintendo 3DS 2015 Circle Pad Replacement: step 11, image 2 of 2
      • Lift the joystick pad and place it on its back. This will reveal the ribbon cable connected to the joystick pad.
      • Use the flat end of the spudger to pry up the retaining flap for the ribbon cable.
      • Lift the joystick out of the device.
      Ask FixBot
6 other people completed this guide.
Michael
181 Reputation
1 Guide authored
Cal Poly, Team 4-6, Livingston Fall 2016 Member of Cal Poly, Team 4-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G6
4 Members
108 Guides authored
4 Guide Comments
thank you for the help
Crichton Vance - Reply Share
Great, detailed tutorial. Was able to sucessfully unscrew my housing of the 3ds. I am currently fixing my circle pad.
Keyboard Smasher Gaming X - Reply Share
Tutorial worked wonderfully, now have a fantastic feeling circle pad on the used N3DS I picked up.
Phantom Kirby - Reply Share
Hi - can some steps be added to replace the actual joystick part of the circle pad? Thanks!
Daniel Griffin - Reply Share
Past 24 Hours: 25
Past 7 Days: 125
Past 30 Days: 478
All Time: 16,279
