Nintendo 3DS 2015 C-Stick Replacement
    1. Nintendo 3DS 2015 C-Stick Replacement, Battery: step 1, image 1 of 1
      • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
      • The screws on the back panel strip easily. Go slowly and press down firmly.
      • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
      Ask FixBot
    2. Nintendo 3DS 2015 C-Stick Replacement: step 2, image 1 of 2 Nintendo 3DS 2015 C-Stick Replacement: step 2, image 2 of 2
      • Pull the top corner tabs of the front face plate outward and towards you.
      • Pull the faceplate up and out of the slots at the bottom of the device.
      • Set aside the back faceplate.
      Ask FixBot
    3. Nintendo 3DS 2015 C-Stick Replacement: step 3, image 1 of 3 Nintendo 3DS 2015 C-Stick Replacement: step 3, image 2 of 3 Nintendo 3DS 2015 C-Stick Replacement: step 3, image 3 of 3
      • Insert a plastic opening tool into the notch at the top of the battery.
      • Pry the battery up with the plastic opening tool.
      Ask FixBot
    1. Nintendo 3DS 2015 C-Stick Replacement, SD Card Reader: step 4, image 1 of 1
      • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
      • The bottom of the SD card reader should slightly pop out after removing the screws.
      Ask FixBot
    2. Nintendo 3DS 2015 C-Stick Replacement: step 5, image 1 of 1
      • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
      • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
      • Reorient the device so that the power jack faces you.
      Ask FixBot
    3. Nintendo 3DS 2015 C-Stick Replacement: step 6, image 1 of 2 Nintendo 3DS 2015 C-Stick Replacement: step 6, image 2 of 2
      • Lift the SD card reader gently.
      • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
      • Lift the SD card reader out off of the lower casing.
      Ask FixBot
    1. Nintendo 3DS 2015 C-Stick Replacement, Lower Case: step 7, image 1 of 3 Nintendo 3DS 2015 C-Stick Replacement, Lower Case: step 7, image 2 of 3 Nintendo 3DS 2015 C-Stick Replacement, Lower Case: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Reorient the device so that the game slot now faces you.
      • Remove the two rubber bumpers along the top of the device using tweezers.
      • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
      Ask FixBot
    2. Nintendo 3DS 2015 C-Stick Replacement: step 8, image 1 of 2 Nintendo 3DS 2015 C-Stick Replacement: step 8, image 2 of 2
      • Lift the top edge of the lower case slightly off on the 3DS.
      • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
      • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
      • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
      Ask FixBot
    3. Nintendo 3DS 2015 C-Stick Replacement: step 9, image 1 of 3 Nintendo 3DS 2015 C-Stick Replacement: step 9, image 2 of 3 Nintendo 3DS 2015 C-Stick Replacement: step 9, image 3 of 3
      • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
      • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
      Ask FixBot
    1. Nintendo 3DS 2015 C-Stick Replacement, C-Stick: step 10, image 1 of 1
      • Remove the four 3mm Phillips #00 screws.
      • Remove the three 3mm Phillips #00 screws.
      Ask FixBot
    2. Nintendo 3DS 2015 C-Stick Replacement: step 11, image 1 of 3 Nintendo 3DS 2015 C-Stick Replacement: step 11, image 2 of 3 Nintendo 3DS 2015 C-Stick Replacement: step 11, image 3 of 3
      Buy
      • Pull up gently on power cable to loose it from the motherboard.
      • Pull the ribbon cable, connected to the mic, gently towards you with a pair of tweezers.
      • Lift the tab to free the large ribbon cable on just above the power connector.
      Ask FixBot
    3. Nintendo 3DS 2015 C-Stick Replacement: step 12, image 1 of 2 Nintendo 3DS 2015 C-Stick Replacement: step 12, image 2 of 2
      • Pry the C-Stick from its plastic housing with the flat side of a spudger.
      • Lift the assembly gently out of the device from the battery connector at the bottom of the leftmost circuit board.
      Ask FixBot
    4. Nintendo 3DS 2015 C-Stick Replacement: step 13, image 1 of 2 Nintendo 3DS 2015 C-Stick Replacement: step 13, image 2 of 2
      • Flip the board over to reveal the connector for the C-stick's ribbon cable.
      • Lift the tab on the ZIF connector securing the C-Stick to the board.
      • Separate the C-Stick from the board.
      Ask FixBot
3 other people completed this guide.
Tyler Starr
1,779 Reputation
7 Guides authored
Cal Poly, Team 4-6, Livingston Fall 2016 Member of Cal Poly, Team 4-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G6
4 Members
108 Guides authored
3 Guide Comments
What do I do if two of my screws were stripped when I got my system? I need to fix my cstick desperately but I cant get inside of my 3ds. Anything at all would help.
~Akiru
Darian Morales - Reply Share
Hello Akiru! Stripped screws can be a bugger, but you do have some options. I could outline some of your options here, but iFixit has a good article for this one. Go ahead and take a look at the article on iFixit titled "How to Remove a Stripped Screw", it should help you out.
Have a Good One.
Tyler
Tyler Starr - Reply Share
you do have the option of just ripping it out
Deo Padilla - Reply Share
Past 24 Hours: 20
Past 7 Days: 104
Past 30 Days: 406
All Time: 22,599
