Up to 20% off select tools
Nintendo 2DS Wi-Fi Card Replacement
Views: 9.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
53
Past 30 Days:
217
All Time:
9,485
Comments: 3
3 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This guide will help you replace the Wi-Fi Card in your original model Nintendo 2DS.
    1. Nintendo 2DS Wi-Fi Card Replacement, Battery: step 1, image 1 of 1
      • Flip over the 2DS.
      Ask FixBot
    2. Nintendo 2DS Wi-Fi Card Replacement: step 2, image 1 of 3 Nintendo 2DS Wi-Fi Card Replacement: step 2, image 2 of 3 Nintendo 2DS Wi-Fi Card Replacement: step 2, image 3 of 3
      • Remove the game cartridge, SD card and stylus if your console has them inserted.
      Ask FixBot
    3. Nintendo 2DS Wi-Fi Card Replacement: step 3, image 1 of 1
      • Undo the 2 Phillips #00 screws.
      • The screws will not completely detach from the battery cover.
      Ask FixBot
    4. Nintendo 2DS Wi-Fi Card Replacement: step 4, image 1 of 2 Nintendo 2DS Wi-Fi Card Replacement: step 4, image 2 of 2
      • Lift the battery cover up and pull it out.
      Ask FixBot
    5. Nintendo 2DS Wi-Fi Card Replacement: step 5, image 1 of 2 Nintendo 2DS Wi-Fi Card Replacement: step 5, image 2 of 2
      • Lift up the battery and remove it.
      Ask FixBot
    6. Nintendo 2DS Wi-Fi Card Replacement, Wi-Fi Card: step 6, image 1 of 1
      • Remove the 10 Phillips #00 screws.
      Ask FixBot
    7. Nintendo 2DS Wi-Fi Card Replacement: step 7, image 1 of 1
      • Carefully remove the rear panel.
      • There's a ribbon cable on the rear panel attached to the motherboard, so be very careful not to damage that cable!
      Ask FixBot
    8. Nintendo 2DS Wi-Fi Card Replacement: step 8, image 1 of 1
      • Pull up the Wi-Fi card from the left side.
      Ask FixBot
    9. Nintendo 2DS Wi-Fi Card Replacement: step 9, image 1 of 1
      • Use a spudger or your fingernail to carefully pull up on the right side of Wi-Fi card. This'll disconnect the Wi-Fi card.
      • There's a cable behind the Wi-Fi card, so be very careful removing it!
      Ask FixBot
    10. Nintendo 2DS Wi-Fi Card Replacement: step 10, image 1 of 1
      • Flip over the Wi-Fi card.
      Ask FixBot
    11. Nintendo 2DS Wi-Fi Card Replacement: step 11, image 1 of 1
      • Use a spudger or your fingernail to remove the cable from the Wi-Fi card.
      Ask FixBot
4 other people completed this guide.
Author
with
Ella
2,344 Reputation
10 Guides authored
3 Guide Comments
Where is the guide for the 2DS Zelda version? I just opened mine up, and there IS NOT a wifi module card anywhere to be seen?! Did they move it UNDER the motherboard? I can not find any guides to the green and brown Zelda 2DS. Mine won’t update or connect to anything now.
Jeremy Patton - Reply Share
It is the same. If you cannot see a Wi-Fi card, there probably is no Wi-Fi card.
Ella - Reply Share
The wifi chip linked is a "2878D-J27H02301" but the one shown in the picture for the 2DS is a "DWM-W082", will either work or do I need to get a DWM-W082?
NullImmer - Reply Share
Past 24 Hours: 6
Past 7 Days: 53
Past 30 Days: 217
All Time: 9,485
