Up to 20% off select tools
Nintendo 2DS Trigger Button Replacement
Views: 37K
View statistics:
Past 24 Hours:
14
Past 7 Days:
83
Past 30 Days:
379
All Time:
37,200
Comments: 23
20 comments on steps, 3 guide comments.
Go to guide comments
Completed: 23
23 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide for the Nintendo 2DS will teach you how to access the trigger buttons to remove them for cleaning or replacement.
    1. Nintendo 2DS Trigger Button Replacement, Battery: step 1, image 1 of 1
      • Remove the two Phillips captive screws securing the upper rear panel.
      • The captive screws will not completely detach from the back panel.
      Ask FixBot
    2. Nintendo 2DS Trigger Button Replacement: step 2, image 1 of 2 Nintendo 2DS Trigger Button Replacement: step 2, image 2 of 2
      • Hinge the upper rear panel upwards and outwards to remove it.
      Ask FixBot
    3. Nintendo 2DS Trigger Button Replacement: step 3, image 1 of 3 Nintendo 2DS Trigger Button Replacement: step 3, image 2 of 3 Nintendo 2DS Trigger Button Replacement: step 3, image 3 of 3
      • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
      Ask FixBot
    1. Nintendo 2DS Trigger Button Replacement, Rear Panel: step 4, image 1 of 1
      • Remove the ten Phillips screws attaching the rear panel.
      Ask FixBot
    2. Nintendo 2DS Trigger Button Replacement: step 5, image 1 of 1
      • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
      • Carefully pull the rear panel straight up from the device.
      Ask FixBot
    3. Nintendo 2DS Trigger Button Replacement: step 6, image 1 of 1
      • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
      • Remove the cable from the connector
      • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
      Ask FixBot
    1. Nintendo 2DS Trigger Button Replacement, Remove trigger button: step 7, image 1 of 2 Nintendo 2DS Trigger Button Replacement, Remove trigger button: step 7, image 2 of 2
      • The trigger buttons have small springs attached to them, so be careful when removing the buttons from the device.
      • Pull the trigger button away from the device to remove it.
      Ask FixBot
23 other people completed this guide.
Author
with
Fina Beauchamp
3,429 Reputation
6 Guides authored
Cal Poly, Team 70-1, Forte Winter 2015 Member of Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 Members
72 Guides authored
3 Guide Comments
Nice job! My right button was jammed for at least two years. Now I can finally demolish my friends in Mariokart.
Minecrafter Pig - Reply Share
Can’t seem to get the second set of screws to budge at all.
Zom baygal - Reply Share
now what????
Karim Eltaib - Reply Share
Past 24 Hours: 14
Past 7 Days: 83
Past 30 Days: 379
All Time: 37,200
