Up to 20% off select tools
Nintendo 2DS Motherboard Replacement
Views: 71K
View statistics:
Past 24 Hours:
20
Past 7 Days:
118
Past 30 Days:
571
All Time:
71,221
Comments: 52
39 comments on steps, 13 guide comments.
Go to guide comments
Completed: 33
33 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 40 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
The motherboard houses all the internal circuitry of the Nintendo 2DS, and the utmost caution must be taken when disassembling it. Be certain not to strip any screws, as that damage my be impossible to fix.
    1. Nintendo 2DS Motherboard Replacement, Battery: step 1, image 1 of 1
      • Remove the two Phillips captive screws securing the upper rear panel.
      • The captive screws will not completely detach from the back panel.
      Ask FixBot
    2. Nintendo 2DS Motherboard Replacement: step 2, image 1 of 2 Nintendo 2DS Motherboard Replacement: step 2, image 2 of 2
      • Hinge the upper rear panel upwards and outwards to remove it.
      Ask FixBot
    3. Nintendo 2DS Motherboard Replacement: step 3, image 1 of 3 Nintendo 2DS Motherboard Replacement: step 3, image 2 of 3 Nintendo 2DS Motherboard Replacement: step 3, image 3 of 3
      • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
      Ask FixBot
    1. Nintendo 2DS Motherboard Replacement, Rear Panel: step 4, image 1 of 1
      • Remove the ten Phillips screws attaching the rear panel.
      Ask FixBot
    2. Nintendo 2DS Motherboard Replacement: step 5, image 1 of 1
      • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
      • Carefully pull the rear panel straight up from the device.
      Ask FixBot
    3. Nintendo 2DS Motherboard Replacement: step 6, image 1 of 1
      • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
      • Remove the cable from the connector
      • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
      Ask FixBot
    1. Nintendo 2DS Motherboard Replacement, Remove Side Panels: step 7, image 1 of 2 Nintendo 2DS Motherboard Replacement, Remove Side Panels: step 7, image 2 of 2
      • Hold the side panels of the device's case with your fingers and pull outward to remove them.
      • The panels should come off easily with little force required.
      • There are three ribbon cables which have already been unplugged in this picture, disconnect these before disassembling the device further.
      Ask FixBot
    2. Nintendo 2DS Motherboard Replacement, Unscrew Motherboard: step 8, image 1 of 1
      • Remove the 12 brass-colored Phillips screws securing the main board.
      • Be very careful not to strip any of these screws. Stripping can occur very easily, and may make replacement of the motherboard impossible.
      • The circle pad has disappeared in this picture. Don't worry, we'll deal with that in the next step
      Ask FixBot
    3. Nintendo 2DS Motherboard Replacement, Remove Top Panel: step 9, image 1 of 3 Nintendo 2DS Motherboard Replacement, Remove Top Panel: step 9, image 2 of 3 Nintendo 2DS Motherboard Replacement, Remove Top Panel: step 9, image 3 of 3
      • The top panel can only be removed when the mother board is not secured.
      • There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
      • There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
      • Hold the top panel with your fingers and pull away from the device to remove it.
      • The top panel should come off easily, with very little force applied.
      Ask FixBot
    4. Nintendo 2DS Motherboard Replacement, Remove Motherboard: step 10, image 1 of 2 Nintendo 2DS Motherboard Replacement, Remove Motherboard: step 10, image 2 of 2
      • Detach the 2 ribbon cables by lifting the black flip connectors that hold them.
      • Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
      • On some models, you'll need to remove three more tiny ribbon cables at the bottom of the screen. They are secured by flip up connectors. BE GENTLE!
      • Holding the motherboard on either side, lift to remove it.
      Ask FixBot
33 other people completed this guide.
Author
with
Fina Beauchamp
3,429 Reputation
6 Guides authored
Cal Poly, Team 70-1, Forte Winter 2015 Member of Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 Members
72 Guides authored
13 Guide Comments
o meu 2ds esta com um defeito que, quando eu aperto o botão de power ele liga e apos alguns segundo desliga e faz um pequeno barulho.
thiagopereira10000 - Reply Share
Would a jis #000 screw driver work better? As i tried a ph +000 and the gold motherboard screws just dont fit right
Demon09 - Reply Share
I have a question. After I replaced the mother board I have been having issues with it freezing after a couple mins running. Do you know why
briana1987be - Reply Share
I have a similar problem. After I replaced mine it will not open any app, and it does not show the status bar. Does anyone know why?
Steve David - Reply Share
Now that I've removed the motherboard, how do I fix it? The instructible is great as far as it goes, but it doesn't go far enough
Danielle Chester - Reply Share
Past 24 Hours: 20
Past 7 Days: 118
Past 30 Days: 571
All Time: 71,221
