Up to 20% off select tools
Nintendo 2DS Joystick Replacement
Views: 50K
View statistics:
Past 24 Hours:
23
Past 7 Days:
142
Past 30 Days:
674
All Time:
49,531
Comments: 33
20 comments on steps, 13 guide comments.
Go to guide comments
Completed: 30
30 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
We will teach you how to first remove the battery and back panel then access the joystick for repair or cleaning purposes.
    1. Nintendo 2DS Joystick Replacement, Battery: step 1, image 1 of 1
      • Remove the two Phillips captive screws securing the upper rear panel.
      • The captive screws will not completely detach from the back panel.
      Ask FixBot
    2. Nintendo 2DS Joystick Replacement: step 2, image 1 of 2 Nintendo 2DS Joystick Replacement: step 2, image 2 of 2
      • Hinge the upper rear panel upwards and outwards to remove it.
      Ask FixBot
    3. Nintendo 2DS Joystick Replacement: step 3, image 1 of 3 Nintendo 2DS Joystick Replacement: step 3, image 2 of 3 Nintendo 2DS Joystick Replacement: step 3, image 3 of 3
      • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
      Ask FixBot
    1. Nintendo 2DS Joystick Replacement, Rear Panel: step 4, image 1 of 1
      • Remove the ten Phillips screws attaching the rear panel.
      Ask FixBot
    2. Nintendo 2DS Joystick Replacement: step 5, image 1 of 1
      • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
      • Carefully pull the rear panel straight up from the device.
      Ask FixBot
    3. Nintendo 2DS Joystick Replacement: step 6, image 1 of 1
      • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
      • Remove the cable from the connector
      • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
      Ask FixBot
    1. Nintendo 2DS Joystick Replacement, Joystick: step 7, image 1 of 2 Nintendo 2DS Joystick Replacement, Joystick: step 7, image 2 of 2
      • Remove the trigger button on the top right corner by pulling upwards and outwards.
      • Remove the right red side panel by pulling outwards.
      Ask FixBot
    2. Nintendo 2DS Joystick Replacement: step 8, image 1 of 1
      • Use a spudger to lift the gray locking lever on the joystick ribbon cable ZIF connector. Pry straight up from the motherboard on the side of the connector opposite the cable.
      • Gently slide the cable straight out of the connector.
      Ask FixBot
    3. Nintendo 2DS Joystick Replacement: step 9, image 1 of 1
      • Remove the two 7.8mm Phillips corner screws holding the white joystick cover.
      Ask FixBot
    4. Nintendo 2DS Joystick Replacement: step 10, image 1 of 2 Nintendo 2DS Joystick Replacement: step 10, image 2 of 2
      • Remove the joystick cover. It should detach with little force.
      • Remove the joystick washer under the joystick cover.
      Ask FixBot
30 other people completed this guide.
Author
with
Fina Beauchamp
3,429 Reputation
6 Guides authored
Cal Poly, Team 70-1, Forte Winter 2015 Member of Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 Members
72 Guides authored
13 Guide Comments
My ribbon cable is broke, Is there a way to fix it?Thanks.
Deez Smith - Reply Share
@deezsmith which ribbon cable? The joystick Flex? If is this Flex, there is nothing we can do, they are extremely fragile. You can buy a new joystick, i guess.
Adrian A - Reply Share
When I put the circle pad back in, my 2DS thinks that I am holding up and right on it, when in reality it is in the neutral position. Please help.
CraftedGamer 1170 - Reply Share
Use the calibrate option in system settings. Also make sure the cable is connected nicely.
Jilvenhong Dickinson - Reply Share
Recalibrate it in system settings.
Artemy Matveev - Reply Share
Past 24 Hours: 23
Past 7 Days: 142
Past 30 Days: 674
All Time: 49,531
