Ninja Ultima BL810 Vent Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
73
All Time:
1,534
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will demonstrate how to remove the plastic vent.
Tools
    1. Ninja Ultima BL810 Vent Replacement, Power Plug: step 1, image 1 of 3 Ninja Ultima BL810 Vent Replacement, Power Plug: step 1, image 2 of 3 Ninja Ultima BL810 Vent Replacement, Power Plug: step 1, image 3 of 3
      • Unscrew the Phillips #0 11mm screws.
      • Unscrew the Torx Security #10 11mm screw.
      Ask FixBot
    2. Ninja Ultima BL810 Vent Replacement: step 2, image 1 of 2 Ninja Ultima BL810 Vent Replacement: step 2, image 2 of 2
      • Unscrew the six Phillips #2 11mm screws from the remainder of the bottom plate.
      • Pull the bottom covering off of the blender.
      Ask FixBot
    3. Ninja Ultima BL810 Vent Replacement: step 3, image 1 of 2 Ninja Ultima BL810 Vent Replacement: step 3, image 2 of 2
      • Unscrew the two Phillips #2 9mm screws.
      • Remove the plastic block.
      Ask FixBot
    4. Ninja Ultima BL810 Vent Replacement: step 4, image 1 of 3 Ninja Ultima BL810 Vent Replacement: step 4, image 2 of 3 Ninja Ultima BL810 Vent Replacement: step 4, image 3 of 3
      • Unscrew the four Phillips #2 11mm screws.
      • Remove the plastic covers.
      • Removing the top cover and then rotating the bottom cover into the same orientation works best.
      Ask FixBot
    5. Ninja Ultima BL810 Vent Replacement: step 5, image 1 of 1
      • Unscrew the three Phillips #2 9mm screws.
      • This metal plate doesn't need to be completely removed, just adjusted to the side to continue working.
      Ask FixBot
    6. Ninja Ultima BL810 Vent Replacement: step 6, image 1 of 3 Ninja Ultima BL810 Vent Replacement: step 6, image 2 of 3 Ninja Ultima BL810 Vent Replacement: step 6, image 3 of 3
      • Pull the power cord through as shown to create slack.
      • Remove plastic casing by lifting upwards.
      Ask FixBot
    7. Ninja Ultima BL810 Vent Replacement: step 7, image 1 of 3 Ninja Ultima BL810 Vent Replacement: step 7, image 2 of 3 Ninja Ultima BL810 Vent Replacement: step 7, image 3 of 3
      • Follow the power plug cords to find the right plastic caps.
      • Squeeze the caps with pliers to loosen the grip.
      • Pull the plastic caps off the twisted wires.
      Ask FixBot
    8. Ninja Ultima BL810 Vent Replacement: step 8, image 1 of 3 Ninja Ultima BL810 Vent Replacement: step 8, image 2 of 3 Ninja Ultima BL810 Vent Replacement: step 8, image 3 of 3
      • Untwist the two wires from each other and pull the zip tie off.
      Ask FixBot
    1. Ninja Ultima BL810 Vent Replacement, Vent: step 9, image 1 of 1
      • Unscrew the 2 Phillips #2 9mm screws.
      Ask FixBot
    2. Ninja Ultima BL810 Vent Replacement: step 10, image 1 of 1
      • Grip the vent on either side and lift it straight in the upward direction.
      Ask FixBot
Ryan James Gilroy
364 Reputation
3 Guides authored
Cal Poly, Team S9-G4, Banghart Fall 2017 Member of Cal Poly, Team S9-G4, Banghart Fall 2017
CPSU-BANGHART-F17S9G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 73
All Time: 1,534
