Ninja Professional Blender BL660 Power Button Panel Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
94
All Time:
2,258
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your blender doesn't power on or is non responsive, then the power button panel may be damaged. This guide will show you how to replace the power button panel on the Ninja Blender BL660.
Tools
    1. Ninja Professional Blender BL660 Power Button Panel Replacement, Blender Base: step 1, image 1 of 2 Ninja Professional Blender BL660 Power Button Panel Replacement, Blender Base: step 1, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
      • Lift the base up to remove it.
      Ask FixBot
    2. Ninja Professional Blender BL660 Power Button Panel Replacement: step 2, image 1 of 2 Ninja Professional Blender BL660 Power Button Panel Replacement: step 2, image 2 of 2
      • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
      • Pull the power cord through the mid-section opening.
      Ask FixBot
    3. Ninja Professional Blender BL660 Power Button Panel Replacement: step 3, image 1 of 2 Ninja Professional Blender BL660 Power Button Panel Replacement: step 3, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
      Ask FixBot
    4. Ninja Professional Blender BL660 Power Button Panel Replacement: step 4, image 1 of 2 Ninja Professional Blender BL660 Power Button Panel Replacement: step 4, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
      Ask FixBot
    5. Ninja Professional Blender BL660 Power Button Panel Replacement: step 5, image 1 of 2 Ninja Professional Blender BL660 Power Button Panel Replacement: step 5, image 2 of 2
      • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
      • Slide the cover all the way to the end of the power cord.
      • Please note that the power cord does not completely come off the cover.
      Ask FixBot
    1. Ninja Professional Blender BL660 Power Button Panel Replacement, Power Button Panel: step 6, image 1 of 3 Ninja Professional Blender BL660 Power Button Panel Replacement, Power Button Panel: step 6, image 2 of 3 Ninja Professional Blender BL660 Power Button Panel Replacement, Power Button Panel: step 6, image 3 of 3
      • Using the Phillips #2 screwdriver, remove the four screws holding the circuit board to the housing.
      Ask FixBot
    2. Ninja Professional Blender BL660 Power Button Panel Replacement: step 7, image 1 of 1
      • Using a pair of scissors, cut the zip ties holding the power wires in order to give the circuit board mobility.
      Ask FixBot
    3. Ninja Professional Blender BL660 Power Button Panel Replacement: step 8, image 1 of 1
      • Using a Phillips #2 screwdriver, remove the 5 screws holding the power button panel cover.
      Ask FixBot
    4. Ninja Professional Blender BL660 Power Button Panel Replacement: step 9, image 1 of 3 Ninja Professional Blender BL660 Power Button Panel Replacement: step 9, image 2 of 3 Ninja Professional Blender BL660 Power Button Panel Replacement: step 9, image 3 of 3
      • Pull the power button panel cover off.
      • The power button panel comes off as a whole unit. Replace as needed.
      • Ninja Kitchen does not sell the power button panel. You will have to purchase one from a third party vendor.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 94
All Time: 2,258
