Ninja Professional Blender BL660 LED Lights Replacement
    1. Ninja Professional Blender BL660 LED Lights  Replacement, Blender Base: step 1, image 1 of 2 Ninja Professional Blender BL660 LED Lights  Replacement, Blender Base: step 1, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
      • Lift the base up to remove it.
      Ask FixBot
    2. Ninja Professional Blender BL660 LED Lights  Replacement: step 2, image 1 of 2 Ninja Professional Blender BL660 LED Lights  Replacement: step 2, image 2 of 2
      • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
      • Pull the power cord through the mid-section opening.
      Ask FixBot
    3. Ninja Professional Blender BL660 LED Lights  Replacement: step 3, image 1 of 2 Ninja Professional Blender BL660 LED Lights  Replacement: step 3, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
      Ask FixBot
    4. Ninja Professional Blender BL660 LED Lights  Replacement: step 4, image 1 of 2 Ninja Professional Blender BL660 LED Lights  Replacement: step 4, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
      Ask FixBot
    5. Ninja Professional Blender BL660 LED Lights  Replacement: step 5, image 1 of 2 Ninja Professional Blender BL660 LED Lights  Replacement: step 5, image 2 of 2
      • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
      • Slide the cover all the way to the end of the power cord.
      • Please note that the power cord does not completely come off the cover.
      Ask FixBot
    1. Ninja Professional Blender BL660 LED Lights  Replacement, LED Lights: step 6, image 1 of 3 Ninja Professional Blender BL660 LED Lights  Replacement, LED Lights: step 6, image 2 of 3 Ninja Professional Blender BL660 LED Lights  Replacement, LED Lights: step 6, image 3 of 3
      • Using the Phillips #2 screwdriver, remove the four screws (10mm long, 5mm wide) on the circuit board.
      Ask FixBot
    2. Ninja Professional Blender BL660 LED Lights  Replacement: step 7, image 1 of 1
      • To give the circuit board further range of motion, remove the pictured zip ties holding the cables.
      Ask FixBot
    3. Ninja Professional Blender BL660 LED Lights  Replacement: step 8, image 1 of 1
      • Locate the malfunctioning LED lights on the circuit board.
      Ask FixBot
    4. Ninja Professional Blender BL660 LED Lights  Replacement: step 9, image 1 of 1
      • Flip the circuit board to view the soldering connections of the LED lights and replace as needed.
      • For instructions on sodering and desoldering reference iFixit's guide.
      Ask FixBot
1 Guide Comment
Buenas tardes.
Muy buenas ilustraciones, pero deben poner los números de partes de los repuestos.
Gracias por la información.
Jose Sosa - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 983
