Ninja Professional BL610 LED Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
106
All Time:
628
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Use this guide to replace the LED on the circuit board of your device.
Tools
    1. Ninja Professional BL610 LED Replacement, LED: step 1, image 1 of 1
      • Remove six screws (12mm long, 6mm head diameter) from bottom of the blender using a Phillips #2 screwdriver.
      Ask FixBot
    2. Ninja Professional BL610 LED Replacement: step 2, image 1 of 1
      • Remove six screws (12mm long, 6mm head diameter) from component housing using Phillips #2 screwdriver.
      Ask FixBot
    3. Ninja Professional BL610 LED Replacement: step 3, image 1 of 1
      • Remove five screws from circuit board using Phillips #2 screwdriver.
      Ask FixBot
    4. Ninja Professional BL610 LED Replacement: step 4, image 1 of 1
      • Once the screws are removed, lift the circuit board to access the back.
      Ask FixBot
    5. Ninja Professional BL610 LED Replacement: step 5, image 1 of 1
      • Locate the LED you wish to replace and note its position on the opposite side of the circuit board.
      Ask FixBot
    6. Ninja Professional BL610 LED Replacement: step 6, image 1 of 1
      • Desolder both of the LED leads and remove the LED light. Note the orientation of LED, this is important for replacing the LED. The Replacement LED needs to be soldered in the same orientation.
      Ask FixBot
Rosniel Castro
482 Reputation
4 Guides authored
USF Tampa, Team S14-G3, Boczar Fall 2017 Member of USF Tampa, Team S14-G3, Boczar Fall 2017
USFT-BOCZAR-F17S14G3
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 106
All Time: 628
