Up to 20% off select tools
Ninja NJ600 LED Light Replacement
Views: 1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
20
Past 30 Days:
98
All Time:
1,014
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
The Ninja NJ600 blender has an LED light display to help the user operate it. This guide will show how to replace one of these lights.
    1. Ninja NJ600 LED Light Replacement, Blender Base Cover: step 1, image 1 of 2 Ninja NJ600 LED Light Replacement, Blender Base Cover: step 1, image 2 of 2
      • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
      Ask FixBot
    2. Ninja NJ600 LED Light Replacement: step 2, image 1 of 2 Ninja NJ600 LED Light Replacement: step 2, image 2 of 2
      • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
      • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
      Ask FixBot
    3. Ninja NJ600 LED Light Replacement: step 3, image 1 of 3 Ninja NJ600 LED Light Replacement: step 3, image 2 of 3 Ninja NJ600 LED Light Replacement: step 3, image 3 of 3
      • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
      • Be careful not to damage the two wires that are keeping this third layer attached to the base.
      Ask FixBot
    1. Ninja NJ600 LED Light Replacement, Circuit Board: step 4, image 1 of 1
      • Remove these four screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
      • Be careful not to scratch the circuit board with the screwdriver.
      Ask FixBot
    2. Ninja NJ600 LED Light Replacement: step 5, image 1 of 1
      • Using a pair of scissors or wire cutters, cut the zip tie holding these wires.
      • This will give the circuit board more range of motion.
      Ask FixBot
    3. Ninja NJ600 LED Light Replacement: step 6, image 1 of 3 Ninja NJ600 LED Light Replacement: step 6, image 2 of 3 Ninja NJ600 LED Light Replacement: step 6, image 3 of 3
      • Desolder the five wires from the solder pads shown.
      • If you do not know how to do this, iFixit has a guide describing the process.
      • Before you begin to desolder these wires, flip the board over to confirm that you are about to desolder the correct component.
      • Soldering iron is very hot, use caution when handling
      Ask FixBot
    4. Ninja NJ600 LED Light Replacement: step 7, image 1 of 1
      • After the wires have cooled enough to touch, carefully slide the circuit board free of the wires.
      • NOTE: keep track of which pad each wire was soldered to. This is important for your blender to function.
      Ask FixBot
    1. Ninja NJ600 LED Light Replacement, LED Light: step 8, image 1 of 2 Ninja NJ600 LED Light Replacement, LED Light: step 8, image 2 of 2
      • Locate the LED you wish to desolder.
      • On the bottom of the board, each LED is designated with a small triangle with a line at one tip.
      Ask FixBot
    2. Ninja NJ600 LED Light Replacement: step 9, image 1 of 1
      • Desolder the two LED leads, and remove the LED from the board.
      • NOTE: the LED is a diode, and requires proper orientation when installed.
      Ask FixBot
Author
with
Nathan Delaney
177 Reputation
1 Guide authored
Cal Poly, Team 24-2, Lancaster Spring 2015 Member of Cal Poly, Team 24-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 98
All Time: 1,014
