Ninja Mega Kitchen System BL770 Power Cord Replacement
  1. Ninja Mega Kitchen System BL770 Power Cord Replacement, Circuit Base: step 1, image 1 of 2 Ninja Mega Kitchen System BL770 Power Cord Replacement, Circuit Base: step 1, image 2 of 2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
    Ask FixBot
  2. Ninja Mega Kitchen System BL770 Power Cord Replacement: step 2, image 1 of 1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
    Ask FixBot
  3. Ninja Mega Kitchen System BL770 Power Cord Replacement: step 3, image 1 of 3 Ninja Mega Kitchen System BL770 Power Cord Replacement: step 3, image 2 of 3 Ninja Mega Kitchen System BL770 Power Cord Replacement: step 3, image 3 of 3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
    Ask FixBot
  4. Ninja Mega Kitchen System BL770 Power Cord Replacement: step 4, image 1 of 1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
    Ask FixBot
  5. Ninja Mega Kitchen System BL770 Power Cord Replacement, Power Cord: step 5, image 1 of 2 Ninja Mega Kitchen System BL770 Power Cord Replacement, Power Cord: step 5, image 2 of 2
    • Check that the two red wires shown in the photos are properly soldered to the circuit board.
    • If they seem damaged, resolder the wires to the board.
    • If this doesn't solve the issue, proceed to step 6.
    Ask FixBot
  6. Ninja Mega Kitchen System BL770 Power Cord Replacement: step 6, image 1 of 1
    • If the 2 wires in the previous step are connected, it's time to check the 2nd area.
    • Remove the plastic covers and check that the wires are soldered correctly.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 34
All Time: 1,516
