Ninja Mega Kitchen System BL770 Cooling Fan Replacement
  1. Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Circuit Base: step 1, image 1 of 2 Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Circuit Base: step 1, image 2 of 2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
    Ask FixBot
  2. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: step 2, image 1 of 1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
    Ask FixBot
  3. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: step 3, image 1 of 3 Ninja Mega Kitchen System BL770 Cooling Fan Replacement: step 3, image 2 of 3 Ninja Mega Kitchen System BL770 Cooling Fan Replacement: step 3, image 3 of 3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
    Ask FixBot
  4. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: step 4, image 1 of 1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
    Ask FixBot
  5. Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Cooling Fan: step 5, image 1 of 2 Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Cooling Fan: step 5, image 2 of 2
    • Using caution, hold the fan steady and use a wrench or pliers to remove the nut securing the fan.
    • Loosen the washer with a flathead screwdriver, then remove the fan and replace with a new one.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 28
All Time: 1,179
