Ninja Mega Kitchen System BL770 Circuit Board Replacement
  1. Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Base: step 1, image 1 of 2 Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Base: step 1, image 2 of 2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
    Ask FixBot
  2. Ninja Mega Kitchen System BL770 Circuit Board Replacement: step 2, image 1 of 1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
    Ask FixBot
  3. Ninja Mega Kitchen System BL770 Circuit Board Replacement: step 3, image 1 of 3 Ninja Mega Kitchen System BL770 Circuit Board Replacement: step 3, image 2 of 3 Ninja Mega Kitchen System BL770 Circuit Board Replacement: step 3, image 3 of 3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
    Ask FixBot
  4. Ninja Mega Kitchen System BL770 Circuit Board Replacement: step 4, image 1 of 1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
    Ask FixBot
  5. Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Board: step 5, image 1 of 2 Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Board: step 5, image 2 of 2
    • Cautiously desolder all the wires connecting the circuit board to the unit.
    • Carefully slide the circuit board free of the wires are place the new board in.
    • Solder the wires back onto the new board, keeping track of which wire goes where in order for your unit to properly function.
    Ask FixBot
7 other people completed this guide.
16 Guide Comments
Thanks for the post… this is helping me with my blender…. by any chance do you have a better picture of the resistor on the back of the circuit board… it seems to be a yellow blue blue gold sequence resistor… my board just burned that resistor and I am trying to find and replace just that resistor if possible… but I am not sure of the colors so I can locate the right now.
Jose Gonzalez - Reply Share
Does somebody know where can I buy this circuit board ??
castro_73 - Reply Share
Anyone know the chip on this circuit board?? Proprietary I assume??
Nathan Walter - Reply Share
Great info but i’m looking to purchase a replacement circuit board for my ninja blender and can not find one. Any ideas?
Rich - Reply Share
hi,, i need to know the reference of transistor with position Q2. in the main board BL770 , thanks.
kolin camacho - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 144
All Time: 8,319
