Up to 20% off select tools
Ninja Mega Kitchen System BL770 Button Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
107
All Time:
3,403
Comments: 11
7 comments on steps, 4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate how to replace any of the push button switches on the circuit board. Each button has four solder pads to desolder. When replaced these must be in the correct orientation in order for the device to work. For soldering help, follow the How to Solder and Desolder Connections guide.
    1. Ninja Mega Kitchen System BL770 Button Replacement, Circuit Base: step 1, image 1 of 2 Ninja Mega Kitchen System BL770 Button Replacement, Circuit Base: step 1, image 2 of 2
      • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
      • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
      Ask FixBot
    2. Ninja Mega Kitchen System BL770 Button Replacement: step 2, image 1 of 1
      • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
      Ask FixBot
    3. Ninja Mega Kitchen System BL770 Button Replacement: step 3, image 1 of 3 Ninja Mega Kitchen System BL770 Button Replacement: step 3, image 2 of 3 Ninja Mega Kitchen System BL770 Button Replacement: step 3, image 3 of 3
      • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
      • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
      • Carefully lift the base up from the rest of the blender.
      Ask FixBot
    4. Ninja Mega Kitchen System BL770 Button Replacement: step 4, image 1 of 1
      • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
      Ask FixBot
    1. Ninja Mega Kitchen System BL770 Button Replacement, Button: step 5, image 1 of 2 Ninja Mega Kitchen System BL770 Button Replacement, Button: step 5, image 2 of 2
      • Locate which button you wish to replace.
      • On the back of the circuit board from the button, there are four solder pads with the designation "SW" followed by a number.
      Ask FixBot
Author
with
Tommee Walker
877 Reputation
6 Guides authored
4 Guide Comments
Hi! I changed the “power button” and when I plugged it back, it went on without the press of the button, and it didn’t work. Think I may have made a lousy soldering job… :/
Luis - Reply Share
Got a dead BL780. Pretty sure it’s the power switch as it’s been harder and harder to push to turn on. Going to attempt to replace on the board. I’m guessing that it’s a tactile momentary switch and that the board controls the power activation instead of the tactile switch being a push on/push off. Any insight would be appreciated.
Mark - Reply Share
Where can I purchase the power button?
Mark
Cenek Picka - Reply Share
Where can buy switch? What part number is the switch?
Mountain Buoy - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 107
All Time: 3,403
