Up to 20% off select tools
Ninja Kitchen System Pulse Motor Replacement
Views: 5.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
200
All Time:
5,408
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 8 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
You will learn how to remove the motor from the base to check for frayed wires and/or loose screws.
    1. Ninja Kitchen System Pulse Motor Replacement, Base Disassembly: step 1, image 1 of 1
      • Take out the three 15 mm Phillips #1 screws.
      • Remove the 15mm T10 screw.
      • Place the 4 screws on the magnetic mat.
      Ask FixBot
    2. Ninja Kitchen System Pulse Motor Replacement: step 2, image 1 of 1
      • Remove the gray base by lifting upwards and placing to the side.
      Ask FixBot
    1. Ninja Kitchen System Pulse Motor Replacement, Motor: step 3, image 1 of 1
      • Remove the three 15 mm Phillips #1 screws.
      • Place screws on magnetic mat.
      Ask FixBot
    2. Ninja Kitchen System Pulse Motor Replacement: step 4, image 1 of 1
      • Remove the motor by gently lifting up. Be careful with the cords, as they may be tangled.
      • This is the entire motor for the Ninja. If you have access to a spare motor, simply swap out the motors.
      Ask FixBot
3 other people completed this guide.
Author
with
DJ
131 Reputation
1 Guide authored
USF Tampa, Team 15-1, Remmell Spring 2016 Member of USF Tampa, Team 15-1, Remmell Spring 2016
USFT-REMMELL-S16S15G1
3 Members
60 Guides authored
1 Guide Comment
Dear sir my ninga kitchen system 1100 (blender machine) motor rod is broken i need help to replace it where i can get the rod or repair shop near me thank you
Noman - Reply Share
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 200
All Time: 5,408
