Up to 20% off select tools
Ninja Kitchen System Pulse Fan Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
98
All Time:
1,521
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
In this guide, we are removing the fan from the base of the Ninja.
    1. Ninja Kitchen System Pulse Fan Replacement, Base Disassembly: step 1, image 1 of 1
      • Take out the three 15 mm Phillips #1 screws.
      • Remove the 15mm T10 screw.
      • Place the 4 screws on the magnetic mat.
      Ask FixBot
    2. Ninja Kitchen System Pulse Fan Replacement: step 2, image 1 of 1
      • Remove the gray base by lifting upwards and placing to the side.
      Ask FixBot
    1. Ninja Kitchen System Pulse Fan Replacement, Fan: step 3, image 1 of 1
      • Remove the central 15 mm length screw, you must hold the fan in place and use a flat head screw driver, twisting counterclockwise.
      • Place this screw on the magnetic mat.
      Ask FixBot
    2. Ninja Kitchen System Pulse Fan Replacement: step 4, image 1 of 2 Ninja Kitchen System Pulse Fan Replacement: step 4, image 2 of 2
      • Remove the fan from the motor by gently pulling upwards.
      • Be careful as to not damage any wires when removing the fan.
      • Set the fan to the side.
      Ask FixBot
3 other people completed this guide.
Author
with
Cameron Just
400 Reputation
3 Guides authored
USF Tampa, Team 15-1, Remmell Spring 2016 Member of USF Tampa, Team 15-1, Remmell Spring 2016
USFT-REMMELL-S16S15G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 98
All Time: 1,521
