Ninja Foodi SP101 Temperature Sensor Replacement
    1. Ninja Foodi SP101 Temperature Sensor Replacement, Feet: step 1, image 1 of 2 Ninja Foodi SP101 Temperature Sensor Replacement, Feet: step 1, image 2 of 2
      • Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
      Ask FixBot
    2. Ninja Foodi SP101 Temperature Sensor Replacement: step 2, image 1 of 1
      • Remove the black lever bar.
      Ask FixBot
    1. Ninja Foodi SP101 Temperature Sensor Replacement, Side Panels: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
      Ask FixBot
    2. Ninja Foodi SP101 Temperature Sensor Replacement: step 4, image 1 of 2 Ninja Foodi SP101 Temperature Sensor Replacement: step 4, image 2 of 2
      • Flip the device upside down and open the bottom panel.
      • Remove the 3 x philips #2 screws along the top edge of the interior using a screwdriver. The Bottom 2 do not have to be removed.
      Ask FixBot
    3. Ninja Foodi SP101 Temperature Sensor Replacement: step 5, image 1 of 3 Ninja Foodi SP101 Temperature Sensor Replacement: step 5, image 2 of 3 Ninja Foodi SP101 Temperature Sensor Replacement: step 5, image 3 of 3
      • Remove the control side panel. To remove it, push forward towards then front control panel to release the tabs out of the main body. Fold away the side panel when the tabs have visually released from their slots in the main body.
      Ask FixBot
    4. Ninja Foodi SP101 Temperature Sensor Replacement: step 6, image 1 of 2 Ninja Foodi SP101 Temperature Sensor Replacement: step 6, image 2 of 2
      • Lift the handle and pull the side panel out.
      • Remove the handle side panel.
      Ask FixBot
    1. Ninja Foodi SP101 Temperature Sensor Replacement, Temperature Sensor: step 7, image 1 of 2 Ninja Foodi SP101 Temperature Sensor Replacement, Temperature Sensor: step 7, image 2 of 2
      • The temperature sensor is found under the handle side panel.
      • The sensor is held down by a rivet. Here is a guide to removing rivets.
      Ask FixBot
Griffin Peterson
664 Reputation
6 Guides authored
1 Guide Comment
Where do you purchase a new temp sensor?
Charles Carlin - Reply Share
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 76
All Time: 2,290
