Introduction
The Ninja Foodi SP101 is known for its sleek metal outer shell. Unfortunately this shell can get blazing hot when cooking and result in burns. An easy fix is to add/replace the insulation found inside of the oven.
Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
