Introduction
The interior heating coils in your Ninja Foodi SP101 are mainly used for the toast and broil features of the oven. The coils reach extreme temperatures, so ensure that they are completely cool and device is disconnected from power before continuing.
Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
Using a Phillips #1 screwdriver, remove the six 8mm screws on inside of the handle-side panel.
9 Guide Comments
Where do you get the replacement element?
Did you find out if you can get the element anywhere?
Has anyone found a viable replacement element being sold?
Same question. The ones on mine say 230V 335W.
