Up to 20% off select tools
Ninja Foodi SP101 Control Panel Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
51
Past 30 Days:
252
All Time:
3,847
Comments: 14
14 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Difficult
Scenic Route
This guide's procedure isn't the most efficient way to get the job done, but still may be useful in some circumstances.
Tools
Introduction
Go to step 1 ↓
The control panel on your Ninja Foodi SP101 is the only way to interact with the oven. It is responsible for controlling the temperature, the mode, and the remaining time to cook. A non-functioning control panel prevents the user from interacting with the device.
    1. Ninja Foodi SP101 Control Panel Replacement, Feet: step 1, image 1 of 2 Ninja Foodi SP101 Control Panel Replacement, Feet: step 1, image 2 of 2
      • Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
      Ask FixBot
    2. Ninja Foodi SP101 Control Panel Replacement: step 2, image 1 of 1
      • Remove the black lever bar.
      Ask FixBot
    1. Ninja Foodi SP101 Control Panel Replacement, Side Panels: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
      Ask FixBot
    2. Ninja Foodi SP101 Control Panel Replacement: step 4, image 1 of 2 Ninja Foodi SP101 Control Panel Replacement: step 4, image 2 of 2
      • Flip the device upside down and open the bottom panel.
      • Remove the 3 x philips #2 screws along the top edge of the interior using a screwdriver. The Bottom 2 do not have to be removed.
      Ask FixBot
    3. Ninja Foodi SP101 Control Panel Replacement: step 5, image 1 of 3 Ninja Foodi SP101 Control Panel Replacement: step 5, image 2 of 3 Ninja Foodi SP101 Control Panel Replacement: step 5, image 3 of 3
      • Remove the control side panel. To remove it, push forward towards then front control panel to release the tabs out of the main body. Fold away the side panel when the tabs have visually released from their slots in the main body.
      Ask FixBot
    4. Ninja Foodi SP101 Control Panel Replacement: step 6, image 1 of 2 Ninja Foodi SP101 Control Panel Replacement: step 6, image 2 of 2
      • Lift the handle and pull the side panel out.
      • Remove the handle side panel.
      Ask FixBot
    1. Ninja Foodi SP101 Control Panel Replacement, Control Panel: step 7, image 1 of 1
      • Remove the 10mm screw using the Phillips #1 screwdriver.
      • This screw connects the motherboard to the motor.
      Ask FixBot
    2. Ninja Foodi SP101 Control Panel Replacement: step 8, image 1 of 3 Ninja Foodi SP101 Control Panel Replacement: step 8, image 2 of 3 Ninja Foodi SP101 Control Panel Replacement: step 8, image 3 of 3
      • Locate the control panel.
      • Slide the top panel outwards and to the right.
      Ask FixBot
    3. Ninja Foodi SP101 Control Panel Replacement: step 9, image 1 of 1
      • Remove the three 8 mm screws with the Phillips #1 screwdriver.
      • These are located on the control panel side that was facing inward.
      Ask FixBot
    4. Ninja Foodi SP101 Control Panel Replacement: step 10, image 1 of 2 Ninja Foodi SP101 Control Panel Replacement: step 10, image 2 of 2
      • Unclip the wires from the motherboard.
      Ask FixBot
    5. Ninja Foodi SP101 Control Panel Replacement: step 11, image 1 of 1
      • Remove the control panel.
      Ask FixBot
3 other people completed this guide.
Author
with
Griffin Peterson
682 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 51
Past 30 Days: 252
All Time: 3,847
