Introduction
This guide will walk you through how to remove the top cover of the Ninja Foodi DZ401.
The top cover is difficult to remove and may be damaged during the process if excess force is applied. The silver ring is purely decorative and may be kept off if desired for ease of access at a later time. The top cover is not decorative and is necessary to protect the interior components of the air fryer.
Position the air fryer so that the front is facing you and the top is accessible.
Using opening picks and a metal spudger, pry open the silver ring on the front, right corner.
Place an opening pick on the left side of the corner to hold the ring away from the cover.
Slide the metal spudger underneath the silver ring. When you find a notch, place the metal spudger next to the notch and pry up to release it.
