Introduction
Go to step 1 ↓Before replacing the motherboard, daughter board, or internal mechanical parts, you’ll need to carefully open the device to expose its inner components. This guide will walk you through the disassembly process required to reach the internal hardware safely.
Be sure to unplug the device and work on a clean, static-free surface. Handle all parts carefully, especially wiring and small connectors.
Tools
On the NC301 model: on the bottom of each side, remove the two Security T-10 screws that attach the grey cover to the black housing.
Use an opening tool to gently lift and remove the grey cover from the top of the main piece.
