Introduction
The outer bowl release button spring allows the Ninja Creami to lock and release the bowl securely during operation. If the button feels stuck, loose, or no longer pops back into place, the spring may be worn or displaced. This guide will show you how to safely inspect, remove, and replace the spring. Always unplug the device before starting to avoid injury.
Remove the ten 14.0 mm Phillips screws from the bottom platform.
Remove the three screws on the bottom platform that are nearest to the center of the bowl platform.
Pry and remove the bottom platform
