Ninja Creami Daughterboard Replacement
    1. Ninja Creami Daughterboard Replacement, Outer Shell: step 1, image 1 of 2 Ninja Creami Daughterboard Replacement, Outer Shell: step 1, image 2 of 2
      • On the NC301 model: on the bottom of each side, remove the two Security T-10 screws that attach the grey cover to the black housing.
      • Use an opening tool to gently lift and remove the grey cover from the top of the main piece.
      • Start at one edge and work your way around to avoid cracking the housing.
      Ask FixBot
    2. Ninja Creami Daughterboard Replacement: step 2, image 1 of 3 Ninja Creami Daughterboard Replacement: step 2, image 2 of 3 Ninja Creami Daughterboard Replacement: step 2, image 3 of 3
      • Remove the ten 13.6 mm Phillips screws from the perimeter of the outer cover.
      • On the NC301 model: you also need to remove the two Security T-10 screws below the button panel and near the rotating shaft housing.
      • Lift the black plastic cover straight up and off.
      • On the NC301 model: the control board behind the button panel is attached to this part and will come off with it. Be careful not to stretch or pull out the ribbon cable that connects it to the rest of the unit.
      Ask FixBot
    3. Ninja Creami Daughterboard Replacement: step 3, image 1 of 2 Ninja Creami Daughterboard Replacement: step 3, image 2 of 2
      • Remove the four 12.2 mm Phillips screws from the black plastic cover.
      Ask FixBot
    1. Ninja Creami Daughterboard Replacement, Daughterboard: step 4, image 1 of 2 Ninja Creami Daughterboard Replacement, Daughterboard: step 4, image 2 of 2
      • Disconnect the daughterboard's motherboard connector.
      • Remove the daughter board.
      Ask FixBot
Karlee B
712 Reputation
6 Guides authored
1 Guide Comment
Hi, where can I buy the schaft? Give me the link, thanks Lucas.
LukeCornerFeno Gmail - Reply Share
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 156
All Time: 1,673
