Ninja Coffee Bar CF080 Heated Plate Replacement
    1. Ninja Coffee Bar CF080 Heated Plate Replacement, Heated Plate: step 1, image 1 of 1
      • Face the machine bottom towards you.
      Ask FixBot
    2. Ninja Coffee Bar CF080 Heated Plate Replacement: step 2, image 1 of 2 Ninja Coffee Bar CF080 Heated Plate Replacement: step 2, image 2 of 2
      • Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
      • Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
      Ask FixBot
    3. Ninja Coffee Bar CF080 Heated Plate Replacement: step 3, image 1 of 3 Ninja Coffee Bar CF080 Heated Plate Replacement: step 3, image 2 of 3 Ninja Coffee Bar CF080 Heated Plate Replacement: step 3, image 3 of 3
      • With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
      Ask FixBot
    4. Ninja Coffee Bar CF080 Heated Plate Replacement: step 4, image 1 of 3 Ninja Coffee Bar CF080 Heated Plate Replacement: step 4, image 2 of 3 Ninja Coffee Bar CF080 Heated Plate Replacement: step 4, image 3 of 3
      • Remove the bottom board with moderate force.
      Ask FixBot
    5. Ninja Coffee Bar CF080 Heated Plate Replacement: step 5, image 1 of 1
      • Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
      • Four screws on each side, two silver secures to remove the securers, located on the sliver bar holding the heated plate (one on each end).
      Ask FixBot
    6. Ninja Coffee Bar CF080 Heated Plate Replacement: step 6, image 1 of 1
      • Unscrew two 0.6cm sized screws Phillips #1 screwdriver.
      • The silver bar will fall off once screws are removed.
      Ask FixBot
    7. Ninja Coffee Bar CF080 Heated Plate Replacement: step 7, image 1 of 2 Ninja Coffee Bar CF080 Heated Plate Replacement: step 7, image 2 of 2
      • Remove the heated plate from the machine with easy glide.
      Ask FixBot
Elizabeth Nguyen
416 Reputation
3 Guides authored
CSU Fullerton, Team S1-G1, Bruce Fall 2017 Member of CSU Fullerton, Team S1-G1, Bruce Fall 2017
CSUF-BRUCE-F17S1G1
4 Members
60 Guides authored
1 Guide Comment
Where do you get a replacement plate at?
Timothy Sick - Reply Share
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 88
All Time: 1,359
