Ninja Coffee Bar CF080 Brewer Head Replacement
    1. Ninja Coffee Bar CF080 Brewer Head Replacement, Brewer Head: step 1, image 1 of 1
      • Face the coffee machine in front of you.
      • Make sure that the coffee machine is unplugged.
      • Remove the glass carafe as it will not be needed.
      Ask FixBot
    2. Ninja Coffee Bar CF080 Brewer Head Replacement: step 2, image 1 of 1
      • Firmly grab the tab sticking out from the head of the brewer.
      Ask FixBot
    3. Ninja Coffee Bar CF080 Brewer Head Replacement: step 3, image 1 of 3 Ninja Coffee Bar CF080 Brewer Head Replacement: step 3, image 2 of 3 Ninja Coffee Bar CF080 Brewer Head Replacement: step 3, image 3 of 3
      • With little force, pull the tab of the brewer head in reverse direction.
      Ask FixBot
    4. Ninja Coffee Bar CF080 Brewer Head Replacement: step 4, image 1 of 1
      • Slide off the head in the direction away from the machine.
      • If the head does not come off smoothly by sliding, give a firm tug in the same direction.
      Ask FixBot
    5. Ninja Coffee Bar CF080 Brewer Head Replacement: step 5, image 1 of 3 Ninja Coffee Bar CF080 Brewer Head Replacement: step 5, image 2 of 3 Ninja Coffee Bar CF080 Brewer Head Replacement: step 5, image 3 of 3
      • Hold the head in the same position and lift it forward until the Ninja is facing upward toward the ceiling.
      Ask FixBot
    6. Ninja Coffee Bar CF080 Brewer Head Replacement: step 6, image 1 of 1
      • Now the brewer head is positioned to where you can seeing the bottom.
      Ask FixBot
    7. Ninja Coffee Bar CF080 Brewer Head Replacement: step 7, image 1 of 2 Ninja Coffee Bar CF080 Brewer Head Replacement: step 7, image 2 of 2
      • Remove the screw with a Phillips #1 screwdriver.
      • Use Phillips #1 screwdriver.
      • Along will come a small black screw cover and spring
      Ask FixBot
    8. Ninja Coffee Bar CF080 Brewer Head Replacement: step 8, image 1 of 1
      • Twist the black lid on top clockwise until it is completely detached.
      Ask FixBot
    9. Ninja Coffee Bar CF080 Brewer Head Replacement: step 9, image 1 of 1
      • With the black upper lid detached, a smaller black cover can be removed without effort.
      Ask FixBot
    10. Ninja Coffee Bar CF080 Brewer Head Replacement: step 10, image 1 of 2 Ninja Coffee Bar CF080 Brewer Head Replacement: step 10, image 2 of 2
      • Remove the 6 screws from the seal with a Phillips #1 screwdriver.
      Ask FixBot
    11. Ninja Coffee Bar CF080 Brewer Head Replacement: step 11, image 1 of 1
      • Once all screws are detached from the brewer head, it will be separated into two pieces leaving the filter.
      Ask FixBot
Elizabeth Nguyen
416 Reputation
3 Guides authored
CSU Fullerton, Team S1-G1, Bruce Fall 2017 Member of CSU Fullerton, Team S1-G1, Bruce Fall 2017
CSUF-BRUCE-F17S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 25
Past 30 Days: 86
All Time: 1,591
