Up to 20% off select tools
Nikon N80 Battery Replacement
Views: 8.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
36
Past 30 Days:
167
All Time:
8,679
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Is your camera not powering up? You may need to change those batteries! This guide will explain how to replace the batteries in a Nikon N80/F80 Camera.
    1. Nikon N80 Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure the On/Off switch is in the Off position.
      Ask FixBot
    2. Nikon N80 Battery Replacement: step 2, image 1 of 1
      • Turn the camera upside down to reveal the battery chamber cover.
      • This camera is missing the battery chamber cover.
      • Slide on the lock lever and remove the battery chamber cover.
      Ask FixBot
    3. Nikon N80 Battery Replacement: step 3, image 1 of 1
      • Turn the camera back over and let the two CR123A/ DL123A batteries slide out.
      • Discard the old batteries responsibly.
      Ask FixBot
    4. Nikon N80 Battery Replacement: step 4, image 1 of 1
      • Use the image on the yellow sticker within the battery chamber to properly place the new batteries back in their compartments.
      Ask FixBot
Author
with
Maegan Viloria
766 Reputation
5 Guides authored
CSU Fullerton, Team 1-7, Bruce Fall 2015 Member of CSU Fullerton, Team 1-7, Bruce Fall 2015
CSUF-BRUCE-F15S1G7
3 Members
60 Guides authored
1 Guide Comment
can cr123a rechargeable batteries be used
David Strom - Reply Share
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 167
All Time: 8,679
