Nikon N2000 (F301) Lens Mount Replacement
Views: 7.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
108
All Time:
7,530
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If you are having trouble mounting the lens and you are sure you have the correct lens type (see the camera manual for types of lenses that can be used), then use this guide to assist with replacing the lens mount.
Tools
    1. Nikon N2000 (F301) Lens Mount Replacement, Lens Mount: step 1, image 1 of 1
      • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
      Ask FixBot
    2. Nikon N2000 (F301) Lens Mount Replacement: step 2, image 1 of 1
      • Remove lens mount from the camera.
      • Be careful not to lose any of the three loose pieces that are under the lens mount.
      Ask FixBot
5 other people completed this guide.
Zachary Phillips
280 Reputation
5 Guides authored
Cal Poly, Team 25-26, Garner Spring 2011 Member of Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Members
72 Guides authored
1 Guide Comment
where can I order the "3 loose pieces and the ring that goes in under the bayonet mount?
penis ripper - Reply Share
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 108
All Time: 7,530
