Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Introduction
Go to step 1 ↓The communication board sends information about the aperture and focus of the lens. If you are having trouble with focus or aperture, then there may be a problem with the communication board.
Tools
Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
6 other people completed this guide.
6 Guide Comments
Doesn't work for the 301, although it looks similar I can't find any way to remove the top or the front case
The F301 and N2000 are identical, so the guide should work. In this guide the top case isn't removed, as the film rewind knob is preventing it from coming off completely, and instead just lifted with the bit of leeway the popped up rewind knob provides.
The small metal post that was under the ring… where does this go? It moved as I lifted the ring and now for the life of me I can figure out where it’s meant to be… help. I opened it up because the black aperture ring was sticking and not springing back when I moved the aperture dial on the lens. My original problem is fixed but now I can’t reassemble my camera.
The only place I could imagine it fitting is inside the spring, just round from the screw at 2 o’clock… is that right?
