Nikon D90 Rear LCD Glass Replacement
  1. Nikon D90 Rear LCD Glass Replacement, Rear Case: step 1, image 1 of 2 Nikon D90 Rear LCD Glass Replacement, Rear Case: step 1, image 2 of 2
    • Slide the eyepiece up and off the viewfinder.
    Ask FixBot
  2. Nikon D90 Rear LCD Glass Replacement: step 2, image 1 of 1
    • Using a PH000 screwdriver, remove the two 4.8mm Phillips screws from the back of the viewfinder.
    • Some screws may be JIS. Be wary of this if your PH000 does not feel like it is properly gripping the screws.
    Ask FixBot
  3. Nikon D90 Rear LCD Glass Replacement: step 3, image 1 of 1
    • Remove the two 6.4mm Phillips screws on the right side of the camera, near the SD card slot.
    Ask FixBot
  4. Nikon D90 Rear LCD Glass Replacement: step 4, image 1 of 1
    • Remove the two 6.4mm Phillips screws on the left side of the camera, near the I/O ports.
    Ask FixBot
  5. Nikon D90 Rear LCD Glass Replacement: step 5, image 1 of 1
    • On the bottom of the camera,
    • remove the two 5.3mm Phillips screws
    • and the other two 6.3mm Phillips screws.
    Ask FixBot
  6. Nikon D90 Rear LCD Glass Replacement: step 6, image 1 of 3 Nikon D90 Rear LCD Glass Replacement: step 6, image 2 of 3 Nikon D90 Rear LCD Glass Replacement: step 6, image 3 of 3
    • Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step.
    Ask FixBot
  7. Nikon D90 Rear LCD Glass Replacement: step 7, image 1 of 2 Nikon D90 Rear LCD Glass Replacement: step 7, image 2 of 2
    • Lift the rear case off of the back of the camera.
    • Don't pull the casing completely off yet, as the ribbon cables are still connected.
    • Be mindful of the two clips, making sure to keep the bottom panel far enough away to clear them.
    Ask FixBot
  8. Nikon D90 Rear LCD Glass Replacement: step 8, image 1 of 1
    • Set the rear casing off to the side so you can access the ZIF connectors.
    • The orientation shown in the picture seems to be the best position for the casing to sit comfortably without stressing the ribbon cable connections.
    Ask FixBot
  9. Nikon D90 Rear LCD Glass Replacement: step 9, image 1 of 3 Nikon D90 Rear LCD Glass Replacement: step 9, image 2 of 3 Nikon D90 Rear LCD Glass Replacement: step 9, image 3 of 3
    • Use a spudger to lift the black tab on the ZIF connector.
    • Disconnect the ribbon cables from their respective ZIF connectors on the logic board.
    Ask FixBot
  10. Nikon D90 Rear LCD Glass Replacement: step 10, image 1 of 1
    • Separate the rear casing from the camera.
    Ask FixBot
  11. Nikon D90 Rear LCD Glass Replacement, LCD: step 11, image 1 of 1
    • Peel back the yellow tape covering the cable connector on the back of the casing you removed.
    Ask FixBot
  12. Nikon D90 Rear LCD Glass Replacement: step 12, image 1 of 3 Nikon D90 Rear LCD Glass Replacement: step 12, image 2 of 3 Nikon D90 Rear LCD Glass Replacement: step 12, image 3 of 3
    • Using the spudger, rock the connector back and forth to disconnect the cable.
    Ask FixBot
  13. Nikon D90 Rear LCD Glass Replacement: step 13, image 1 of 2 Nikon D90 Rear LCD Glass Replacement: step 13, image 2 of 2
    • Remove the eight Phillips screws securing the brackets to the rear casing.
    • Four 4.2mm screws securing the large metal bracket.
    • Four 3.4mm screws securing the bracket that covers the ribbon cable.
    Ask FixBot
  14. Nikon D90 Rear LCD Glass Replacement: step 14, image 1 of 2 Nikon D90 Rear LCD Glass Replacement: step 14, image 2 of 2
    • Remove the silver metal plate.
    Ask FixBot
  15. Nikon D90 Rear LCD Glass Replacement: step 15, image 1 of 2 Nikon D90 Rear LCD Glass Replacement: step 15, image 2 of 2
    • Fold the ribbon cables up and out of the way.
    • Remove the metal shield covering the LCD.
    Ask FixBot
  16. Nikon D90 Rear LCD Glass Replacement: step 16, image 1 of 2 Nikon D90 Rear LCD Glass Replacement: step 16, image 2 of 2
    • Lift and remove the LCD from the rear case.
    Ask FixBot
  17. Nikon D90 Rear LCD Glass Replacement, Rear LCD Glass: step 17, image 1 of 2 Nikon D90 Rear LCD Glass Replacement, Rear LCD Glass: step 17, image 2 of 2
    • Using either the iOpener or a heat gun, heat the rear LCD glass enough to melt the adhesive holding it on.
    • The glass will be hot! Let cool before handling.
    Ask FixBot
  18. Nikon D90 Rear LCD Glass Replacement: step 18, image 1 of 1
    • Push the glass out from the back side.
    Ask FixBot
9 other people completed this guide.
Ryan Lutz
3,095 Reputation
3 Guides authored
1 Guide Comment
I did this but when I put the lcd back on it only displays black
Jeremiah Wessling - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 44
All Time: 4,879
